whew!!! Finally, here it is! audio shows up fine but doesn't work, no battery icon. :)
The config.plist is not upto the mark. You did NOT followed the guide. Follow the guide here:
😥 I don't understand how the config.plist isn't up to the mark.. Please put it in a layman's term 😣
The guide explains very well how to grab the config.plist for your hardware. You must read it carefully. The guide also explains how the Clover directory should be, what kexts to use and related things. For more information, try to read "Selecting a Config.plist File" and the related notes in the same guide.
I did that... I mean i replaced my config.plist with the one in the guide and i couldn't boot so i will do a fresh reinstall after using paragon apfs to pull out my documents, apps and data then i will reextract and re-upload my files 🙂
If you couldn't boot, you could have attached your Clover files along with the error message you get. If it doesn't boots, it doesn't means that you can change the config.plist and expect things to work.
Follow the guide and where you encounter issue, provide us the files and screenshot to help.
Well I'm reinstalling already 😑 i will post an update soon!
It's looking good so far I'm currently returning my files to my hackintosh. Surprising enough, i have a battery icon the only thing that's odd is that it reports false battery capacity. I will download pr reporting script and post files soon
Sure. When submitted, i'll have a look. :)
Reactions: Chucksmmadu
Finally generated the file! Here it is. 🙂
Toilettrauma
