CPU Compatibility List For macOS [Intel/AMD]
You can install it but the Graphics won't work at least for now.
When it can be installed natively, why try to install it on a Virtual Machine?
According to which instruction should I install?
I need windows software, is it possible to install sonoma without deleting windows?
What's the purpose when the Graphics will not work?
Yes, you can install on it.
Hey I wanted to know if my Laptop is supported
Ryzen 5 5600h and rtx 3050 (no mug switch)
I am totally fine installing with my igpu but i need the proper suggestions on how to do it. I previously followed opencore guide but got stuck in kernal panic and couldn't fix. I mainly have problem creating EFI for my system, can you guys help?
I need Mac OS to downgrade Apple phones or jailbreak them. No need for a graphics card.
Then you can install it.
Yes, its supported.
I have Ryzen 5 3450u, is that supported?
Hi,
Sir, can i install macos Sonoma on Dell Inspiron P117F with Cezanne CPU?
If so, can I ask for instructions?
Hi,
What's the CPU model?
Fill in your profile information first!
J.An
