CPU Compatibility List For macOS [Intel/AMD]
AMD Cezanne does support hackintosh ventura?
I have an Asus M513 laptop
AMD Lucienne (Zen 2, Ryzen 5000) R5 5500U
can I install Ventura OS on this laptop?
Yes, you can.
hello
I have an Asus laptop with a Ryzen Zen 2 5500 u CPU and Vega 6 GPU I guess and I want to know if this laptop can handle Mac OS Ventura or not.
tnx
Yes, you can.
tnx but in the table it doesn't check yes as supported cpu sir
hello
tnx
It can run macOS Sonoma.
I have an Asus FA507RC laptop with a Ryzen 7 6800H CPU.
Can a variation of mac be installed on my laptop?
It doesn't matter to me whether it can be installed on the hard drive or run with one of the virtual machines.
Which method should I use?
You can install it but the Graphics won't work at least for now.
When it can be installed natively, why try to install it on a Virtual Machine?
kcbednar
