Correct settings Intel graphic Kaby Lake-R [Intel UHD 620] on Surface Pro 5?
olekor
Surface Pro 5
Intel(R) Core(TM) 7th-generation i5
Intel(R) HD Graphics 620
I'm having trouble finding the correct AAPL, ig-platform-id, device-id and framebuffer patch types to use on my Kaby Lake-R [Intel UHD 620], Ventura 13.6.1, Microsoft Surface Pro 5 (7th Gen Intel® Core™ i5, 8 GB RAM, SSD 256 GB, Mini DisplayPort) device. I've tried multiple options but haven't achieved the desired result. With the last option, the image on the screen was of very high resolution, making it impossible to see, and there was no output to an external monitor via mini DP. With previous options, the output was only to an external monitor, and the tablet screen remained black because the backlight did not turn on. I am baffled and need help finding the right option.
  • congig play list.txt
591B0000 as ig-platform-id and 59160000 as device id.
However, additional framebuffer patching is required due to the UHD/QHD panel requirements.
Thank you for getting back to me. Unfortunately, I tested different parameter variants, but nothing has changed. I believe the form should be correct:
AAPL, ig-platform-id = 00001B59, device-id = 59160000. Is correct?
I have attached some pictures, that maybe to help you identify issues and provide advice on how to fix them. Honestly, I am feeling frustrated as I have installed Hackintosh on different computers before, including the Surface Book 2, but I have never encountered such a silly situation. This problem happened a couple of days later after the successful installation and using Ventura when I once time connected the external monitor and then next switched without an external one I received a black screen tablet. I tried to fix it but finally got too stuck.
I would be grateful for any assistance in finding a solution.
Use the following values in DeviceProperties of your config.plist
AAPL,ig-platform-id = 00001B59
device-id = 16590000
Check your inbox!
xmax114
