Z790 Gaming X AX USB issue with Mojave
zzmadd
Gigabyte Z790 Gaming X AX DDR5
Intel Core i7 14700KF
Radeon RX 580 8GB
10.14.x
  1. iMac Pro
Hi all,
I'm looking for advices how to solve an issue I have.
Mobo: Gigabyte Z790 Gaming X AX DDR5, CPU Intel 14700KF, GPU Radeon RX 580 8GB.
On Ventura all perfect.
The main issue in Mojave, which I also need as an OS is USB 3.0
I can only get USB 2.0 to show up. I can get all USB 2.0 ports
If I use the SSDT created, in Mojave, I only see the USB 2.0 portion of it, all the USB 3.0 SSxx ports are missing
USB device is 7A60
If I use USBInjectAll 080 or copy into the USBInjectall 071 the device id definition nothing changes
If I use the USBPort.kext I get the same issue
I tried dropping in a couple of verions of XHCI-Unsupported without success
Can anyone help?
Thanks a lot!
Hi all,
USB device is 7A60
Can anyone help?
Thanks a lot!
Use XhciPortLimit quirk and then map your ports. It should be all good.
Hi,
thanks for your reply.
The XhciPortLimit quirk doesn't do anything.
USB 3.0 ports are not shown by the quirk or by a pre mapped SSDT that works in Ventura.
Same thing for USBPorts.kext driver. It only shows USB 2,0 ports.
The same driver shows all the porta, including USB 3.0 in Ventura.
It's like Z790 USB 3.0 are not compatible.
Hi,
That's not the case cause having a Mojave machine where everything works fine. Yes, it's Z790.
You need to disable the previous mapping and then use XhciPortLimit quirk to discover all your ports. If your board has some other controller than Intel, you'll need a driver for it.
The board has only the Z790 chipset for USB.
If I enable the XhciPortLimit quirk I ONLY see USB 2.0 ports.
Did you disable the prevous work?
In short, you'll need XhciPortLimit Quirk+USBInjectAll+XHCIUnsupported. You must disable the previous SSDT/mapped kexts. Make sure to reset NVRAM twice.
Also, make sure to use the latest versions of the kexts.
Ok,
thisis what I did:
- ResetSystem: twice
- CleanNVRam: twice
- No SSDT for USB of any kind
- Enable XhciPortLimit Quirk
- Enabled USBInjectAll 0.8.0
- Added XHCIUnsupported
- Disabled any USBPorts kext
And I get....
What I just said: NO USB 3.0 Ports
Ok,
thisis what I did:
- CleanNVRam: twice
And I get....
Here it is.
Ventura everything work.
The issue is in Mojave only:
- No USB 3.0
- Had to use VooDooHDA as Apple ALC doesn't get audio to work
The EFI you see if not the EFI I tested before under your guidance. I reverted to my own compromise of a missing USB 3.0 in Mojave
EFI here:
Here it is.
- No USB 3.0
EFI here:
As expected, your configuration is quite messed up. You should stop USBPort kexts from loading as stated before. XHCIUnsupported is missing as well.
Read post #6 carefully.
alexito
