This is a complete installation guide to install macOS Mojave 10.14 on your custom built hardware featuring Gigabyte Gaming B8 paired with i3 7100. The purpose of this guide is to provide a step-by-step guide to install Mojave using Clover UEFI.
Specifications
Motherboard: GIGABYTE GAMING B8
CPU: Intel Core i3-7100
RAM: 8 GB 2400MHz
Graphics: NVIDIA GT 710 2GB
Monitor: LG
SSD: Transcend
Ethernet: Intel I219-V
Audio: Realtek ALC1220
Summary
What's works?
Audio ✔
Graphics ✔
Ethernet ✔
WiFi/Bluetooth
HDMI ✔
Power Management ✔
iMessage ✔
FaceTime ✔
iCloud ✔
USB 2.0, 3.0, 3.1 and USB Type-C Ports ✔
Not working
Everything works so far.
Bootable Media Creation
To create a Bootable media for Mojave, follow the steps below.
1. Insert your USB Flash Drive and open Disk Utility. The Disk Utility is located at /Applications/Utilities/Disk Utility
2. Select your USB Flash Drive in the left pane and click on Erase button, at top.
3. A pop-up will appear.
4. Under Name type USB
5. Under Format select Mac OS X Extended (Journaled)
6. Under Scheme select GUID Partition Map, and click on Erase.
7. When done, click on Done.
8. Launch terminal, located at /Applications/Utilities/Terminal.
9. Copy and paste the following sudo command in terminal.
10. Enter your password
11. Press (Y) to confirm and then press enter key and it will start to erase the disk and will create macOS Bootable USB.
Once the process completes, close the terminal. The USB Flash Drive will be renamed as Install macOS High Sierra
Install Clover Bootloader
The next step is to install the Clover Bootloader to your USB Flash Drive.
1. Download Clover EFI Bootloader.
2. Extract the Clover EFI bootloader installer package and right click on the .pkg file and select Open
3. By default, the Clover Bootloader will select the system drive i.e Macintosh HD. Simply click on Change Install Location and select your installation Drive i.e Install macOS Mojave.
4. Click on Customize and configure the following settings.
6. Confirm the above options and click on Install. When promoted, enter your password. The clover bootloader will be installed to your installation drive.
7. Once done, simply click on Close
After installing the Clover bootloader, the EFI partition should be mounted on your Desktop.
Now you’ve successfully installed clover and the required drivers on your USB.
Placing required kexts
In order to boot into the installation, you need to place the necessary kexts. Follow the guide below to place the necessary kexts.
Downloads
Navigate to /EFI/CLOVER/kexts/10.14/ and place all the 3 kexts (FakeSMC.kext, VoodPS2Controller.kext and USBInjectAll.kext)
Preparing Post Installation Tools
The next step is to place the required tools, kexts to the another Flash Drive which will help you in the post installation.
1. Insert your another USB
2. Format the USB with the following parameters
Under Name type Post Install
3. Copy the important tools such as DPCIManager, Clover Configurator, IOReg, MaciASL.
4. Copy Intel I219-V Ethernet kext so that you can have a working Internet connection on your build.
5. Copy AppleALC, Lilu so that you can have a working Audio on your build.
When done, simply eject your second Flash Drive.
Copy the Config.plist
I've written a guide to create a config.plist. Read here: https://www.elitemacx86.com/threads/guide-creating-a-basic-config-plist-file-for-booting-macos.257/
1. Download the config.plist file from the above linked guide.
2. Open the config.plist file using Clover Configurator.
3. You need to set the SMBIOS to iMac 18,3. The rest will be same as in the config.plist sample.
UEFI Settings
To access your BIOS/UEFI, press and hold Delete key on your Keyboard and then set the following.
Set Optimized Defaults.
Set X.M.P. Memory Profile to Profile 1.
Set Fast Boot to Disabled.
Set Windows 8/10 Features to Other OS.
Set Initial Display Output to PCIe 1 slot.
Set Intel Platform Trust Technology (PTT) to Disabled.
Set Network Stack to Disabled.
Set XHCI Hand-Off to Enabled.
Set SATA Mode to AHCI.
Set VT-d to Disabled.
Set Internal Graphics to Auto.
Save & Exit Setup.
Installation
Follow the steps below for the installation.
1. Turn on your PC
2. Press F12 to enter boot menu.
3. Select your USB Flash Drive with the UEFI prefix and press enter to boot.
4. When at Clover screen, select Boot macOS Install from Install macOS Mojave.
5. It will take couple of minutes to boot into installer screen. Once you reach the installer, select your preferred language and continue.
6. For a fresh installation, you must erase the drive you wish to install on. Follow the steps below to erase the destination drive.
7. On top, click on Utilities and then select Disk Utility.
8. When at Disk Utility, click on View and select Show all Devices.
9. Now select the SSD.
10. Make sure that you don’t select partition, select the Drive and click on Erase button.
Under Name type Macintosh HD.
Under Format select Mac OS Extended (Journaled).
Under Scheme select GUID Partition Map, and click on erase button.
Close Disk Utility
11. Select Install macOS and continue with the options.
12. Now select Macintosh HD and click on Install.
13. Upon completion, the system will automatically restart. The system may restart few times to complete the installation.
14. If the system restarts, select Boot macOS Install from Macintosh HD.
15. After installation, boot it using USB, but this time select Macintosh HD.
16. The first boot maybe slower as the caches are not build yet. Once the caches are built, it will boot normally.
17. When you're at the welcome screen, continue with the basics options such as Keyboard setup, Network, Computer Account and Privacy settings.
Now the installation is complete, but the drive isn't bootable yet. You need to configure the Post Installation
Post Installation
Now, configuring the Post Installation
The post installation is required to achieve the fully system functionality.
Typically, the post installation includes enabling boot from the system drive, Graphics, Network, Audio, and USB.
Boot from System Drive
Mount the EFI Partition.
Be sure to mount both the EFI partitions of your Hard Drive and macOS Sierra Bootable USB. Both the EFI partition of your Hard Drive and USB Flash Drive will be mounted on your Desktop.
Assuming that you’ve mounted your EFI Partition, continue the following.
1. Open your EFI Partition of your Hard Drive.
2. Select EFI folder and then move to Trash.
3. Now open your EFI Partition of your macOS Sierra Bootable USB.
4. Now copy the EFI folder to your EFI Partition of your Hard Drive.
By using this method, You’ll able to install Clover Bootloader automatically to your Hard Drive.
This build is having NVIDIA GT 710 Graphics Card. The GPU works out of the box.
Network
The motherboard uses Intel I219-V Ethernet Chipset. All you need to do is to install the kext and reboot the system in order to activate Ethernet. The downloads for Intel Ethernet is available in the downloads section.
Audio
The motherboard uses a Realtek ALC1220 Audio Codec. The codec delivers a high Output Audio quality with Smart Headphone Amp.
There are several ways to activate audio. I'm using Apple ALC to enable audio on this build.
Download the Apple ALC and Lilu kexts
Extract the kexts
Navigate to : EFI/Clover/Kexts/10.14 and place both the kexts
USB Ports
There are two USB Chipset used by this motherboard. The default Chipset from Intel and the ASMedia for USB Type-C and Type-A. The ports works OOTB. All the USB ports are activated by default.
Mount your EFI Partition
Open your config.plist file using Clover Configurator
Navigate to kernel and kext patches tab and add the following patch in your config.plist.
Save your config.plist file
Restart your System
After completing the post installation, restart your system.
Specifications
RAM: 8 GB 2400MHz
Monitor: LG
SSD: Transcend
Summary
What's works?
Audio ✔
Graphics ✔
Ethernet ✔
WiFi/Bluetooth
HDMI ✔
Power Management ✔
iMessage ✔
FaceTime ✔
iCloud ✔
Not working
- Install Clover for UEFI booting only
- Install Clover in the ESP
- Themes: Select any
- Drivers64UEFI: AptioMemoryFix-64 and ApsDriverLoader-64
- Do not forget ApfsDriverLoader-64 to install.
- With the use of AptioMemoryFix-64, you don't need to use EmuVariableUefi-64.
- Do not install AppleKeyFeeder-64 from Drivers UEFI.
Downloads
- FakeSMC.kext : https://github.com/RehabMan/OS-X-FakeSMC-kozlek
- VoodooPS2Controller.kext : https://github.com/RehabMan/OS-X-Voodoo-PS2-Controller
- USBInjectAll.kext : https://github.com/RehabMan/OS-X-USB-Inject-All
- Use the kext from Release folder.
UEFI Settings
Save & Exit Setup.
Installation
1. Turn on your PC
Close Disk Utility
Post Installation
Network
Audio
Extract the kexts
- Use layout id=11 only. If you use any other layout, there maybe distortion with the Speakers or the Headphones.
- Use the kexts from RELEASE.Zip only
- This will also enable HDMI Audio for this specific GPU.
USB Ports
- With the release of macOS Mojave, a new USB port limit patch has been introduced.
Find* [HEX]: 83FB0F0F 83030500 0
Replace* [HEX]: 83FB0F90 90909090 90
Comment: USB 10.14.x by PMHeart
MatchOS: 10.14.x
Restart your System
