SOLVED Does a ASUS ROG G14 (2020) actually support a hackintosh ?
It seems i have a problem with my nvme in pci express, because it seems macOS can't write in my disk...
(solved by erasing all the partitions)
The installer crash randomly on the copying file system after 20 or 25 minutes.
But the data is well copied (but not entirely i guess, here is 13,45gb used after crash).
How i can find the problem ? (there is my last config plist file)
Thanks.
And it's not only on the installer, the macOS recovery could also crash after 10 to 30 minutes.
Thanks.
Ok i try like this (sorry if it's in the guide), and it's HfsPlus.efi who go more longer in the debug installer.
Following the guide will eliminate several issues ;)
Thanks.
Attach your complete PR Files.
Thanks.
Sounds like an NVMe issue. What's the target disk model?
What is PR file ? And the NVMe is an Intel SSD. But it crash even in safari (for exemple) after 20 or 30 min. You really think is the problem is about the NVMe ?
PR Files are Problem Reporting Files.
There are several Intel NVMe SSDs. You should at least provide the model number.
How can i get these files ? And it's a screen of disk util when i erase the disk (i think it's probably the serial number).
moraWooChang
