Help how do I configure my motherboar to make a hackintosh assrock z270 extreme 4
shade lich
ASRock Z270 Extreme4
Intel Core i7-7700K @ 4.20GHz kabyLake
Nvidia Rtx 2070 super
I have an asrock z270 extreme 4 with an intel i7 7700k kabylake processor 32 gb of ram at a frequency of 2400 I have already installed the efi in my memory and I have everything ready to install the operating system but my doubt and fear problem is in the bios since it is not I know what to configure exactly and since I installed mac the first time and almost and I had to reset the factory motherboard since not knowing what to configure in my bios the pc marked a temperature of 100 degrees and apart from that the rams stopped working Since everything was due to a bad installation of how not having configured the bios, then can someone who has this board and already installed hackistosh help me with that problem? I would really appreciate it with all my heart
sorry for my english I think you know I'm using a translator another thing I think I found a possible solution for the bios issue with this video since my bios is very similar to the one in the video although I'm afraid because they are not the same motherboard but As I see, let's say they are the same bios if they think it will work for them?
You can follow the video and do what settings are available. What's not available, you can skip them.
hello here eh I leave you all the possible image to help me I thank you very much
Adjust the following.
XHCI Hand-off = Enabled
Intel Thunderbolt Technology = Enabled (If you want to use Thunderbolt)
VT-d = Disabled
Serial Port = Disabled
mykal
