SOLVED Does a ASUS ROG G14 (2020) actually support a hackintosh ?
Z2VvZ2Vv
Acer Veriton X2631G i5 4460
i5 4460
GT 1030
Hey ! I wanted to know if my laptop could support a hackintosh.
There is the configuration of my laptop :
Ryzen 7 4800HS (i know the rtx doesn't work on it)
-> APU : AMD Radeon Graphics (doesn't know the model)
RAM 32 Go
NVIDIA GeForce RTX 2060
If it's good please tell me the kexts i've to choose, and if not, the virtualization of macOS with unraid or a KVM hosted machine, is a good idea or is better to stay on Linux ?
Thanks.
RAM 32 Go
Thanks.
Your hardware is supported and you can install it on a Bare Metal.
Hi ! I'm back, all the day i tried to install macOS but i'm blocked.
When i choose the installer option on OpenCore i have debug (see pics) and nothing after a black screen (with the minimum kexts) and with all my kexts (see the config file) after 2 or 3 seconds it reboot.
For the configuration : i've disabled virtualization (SVM in my case), secure boot, fast boot and thts it.
I've tried everything, i want to know if is an error of configuration or an incompatibility. I don't see what's the problem, i thought it was some kexts of wifi and bluthooh but no.
Thanks in advance for the time you give me !
  • config.zip
    config.zip
Why are you using EnableWriteUnprotector and RebuildAppleMemoryMap and HfsPlus and OpenHfsPlus together?
In addition, you'll need to disable your unsupported GPU.
Ok i will change that, i just belived that we have to use the two Hfs together.
And for EnableWriteUnprotector and RebuildAppleMemoryMap i disable right now !
For the GPU, in my bios i haven't the options to force disable GPU, how can i do it ? Because i was thinking that GPU is by default disabled and with some software (in windows) it used the GPU when he wants ?
I just do the modifications, and it crash before validate root dmg, after just 2 or 3 second and it reboot.
I will do some tries with the minimum kexts (i've using OpenHfsPlus.efi)
Disable EnableWriteUnprotector and enable RebuildAppleMemoryMap.
For the unsupported GPU, you can disable using -wegnoegpu boot arg. It's already explained in the guide.
Use the kexts as instructed in the guide. Nothing extra. Extra things can be configured later once you're done with the installation.
Ok i try like this (sorry if it's in the guide), and it's HfsPlus.efi who go more longer in the debug installer.
Finally i can launch the installer !! Thanks. I havn't the trackpad, but i think i will adjust this after !
Roberto Sales
