How to install MacOS on B760M system?
dogusyolal
ASRock B760M PG Sonic WiFi DDR5
Intel Core i5-13400F
Asrock RX 6900 XT Phantom Gaming D
RAM: Corsair 32GB RAM 6200MHz
SSD or HDD model: Kingston 1TB Fury Renegade, WD Blue 2TB Harddisk
Graphics card: ASRock Radeon RX 6900XT Phantom
Motherboard: ASRock B760M PG Sonic Wi-Fi
Processor: i5 13400f
I tried to install Ventura on my system before, but I was not successful. Even though I made EFI adjustments etc., I couldn't come to a conclusion. Which version of macos do you recommend me to use? And if I install Ventura and then update it to Sonoma, will it be a problem? Thanks in advance.
You can either install Ventura or Sonoma.
You can also check the Video guide
I created an efi file and passed many errors, but I could not find how to solve the error in the picture.
The EFI you have attached is not build as per the guide linked above.
Start again from scratch:
natsukiro
