No wifi/bluetooth MSI Z790-p pro wifi DDR4
Alegundam
msi pro z790-p wifi ddr4
i5 13600kf
rx 6900 xt
  1. iMac Pro
Hi everyone, I installed sonoma with your guide and I only have the wifi and bluetooth problem. I followed the guide to resolve this but I don't understand which card I have and therefore which kexts I need to install. I did some tests but nothing. Can someone help me? Thank you
Not sure which WiFi/BT module you have. If you can provide some info, we can help.
hello, i have msi pro z790-p wifi ddr4, i5 13600kf, gpu RX 6900 XT. I don't know what other information I can give you.
Furthermore, with high sierra and clover I was able to configure my smbios and now with opencore I can't understand how to set up my PC to also use it to answer the phone. Facetime works, but I can't make calls. Thank you.
I attach my efi
I attach my efi
You can check the WiFi module using Hackintool>PCIe. Attach the .txt or a picture to confirm the model.
is this?
Looks like. FYI, the WiFi seems to be Intel. For Intel WiFi/BT, do not expect full functionality like a native card. If you need such features, replace with a compatible one.
I already have a working USB AC1200M for WiFi, but unfortunately localization doesn't work. It only works with native wifi. This is why I want to solve it. I don't understand why after putting the airport kext the wifi doesn't work. I hope someone helps me
Its simply not supported. If you have Intel WiFi, simply use the built in with Airportitlwm and you should be good. No need to use the USB one.
I know I have intell Wi-Fi and I already tried to use Airportitlwm but it doesn't work the same. that's why I attached my letter. Maybe someone can figure out the problem by looking at my letts and my config.plist
This is my actual EFI. Bluetooth is ok but native wifi doesn't work
alvarg82
