SOLVED EFI for Vega 8 Sonoma
p04w04p5
MSI A320M-A PRO
Ryzen 3 3200G
Vega 8
I installed the Sonoma version on the system without any problems. However, even though I edited the EFI folder without any problems, the system does not boot when I activate the NootedRed kext. It gets stuck on the Verbose screen.
I share the EFI folder I use via Drive.
Reactions: p04w04p5
Should I just change the incorrect part instead of preparing it again? Or do you recommend that I prepare the EFI folder according to the manual again?
Starting from scratch is a better idea.
We have a video guide on our channel. You can follow that.
  • Love
Reactions: p04w04p5
By looking at the guide on the forum, I booted my system without any problems. I am grateful to you, thanks.
But even though I uploaded the ALC kext file, there is no sound. I have a headset with a built-in sound card. I was using it in the Big Sur version without any problems.
Attach the EFI you're using. Include the System Report and a copy of IOReg. Also, what's the Audio Codec?
Reactions: p04w04p5
A different device was selected in the sound settings. When I selected my headphones it worked. So there is no problem in the EFI folder.
Sounds good!
Closing this thread.
  • Love
Reactions: p04w04p5
dizzjk
