Ventura 13.6 only boots every ~third time on Raptor Lake
detectivepundit
Gigabyte Z790 UD AX
Intel Core i5 13500
Sapphire Pulse AMD Radeon RX 6600 8GB
Hello, good day
I've installed Ventura 13.6
The system doesn't always boot correctly. About 4 out of 6 attempts, it fails just before loading the GUI and initiates a reboot.
This cycle repeats until it boots up successfully, after which everything functions properly.
I'm unfamiliar with this particular issue and am unsure how to pinpoint the cause.
Thanks in advance!
Hello, good day
Thanks in advance!
Attach your PR Files to check further.
Hello!
thanks for your prompt reply
does that mean EFI folder? please
Sure
will send you the EFI folder
Thank you once again!
Hi!
Here is the EFI and IORegistry in the zip file.
I truly appreciate your help.
it says the file size is too large for the server to process
here is the Gdrive link drive.google.com
Thank you!
Hi!
Thank you!
Does configuration mean config.plist?
thank you!
another issue I have been facing is that after the system starts my USB keyboard stops working and have to unplug then re-plug it to make that work but the USB mouse works perfectly. Did the USB mapping in windows by USB Tool box.
fly.gao
