Tracking down random Kernel Panics after Sonoma Install . Any help would be greatly appreciated .
You were supposed to attach the video where you noticed lags.
Attached video showing lags. (benchmark) If you could be more specific in your replies, it would be great appreciated.
Desktop Pic showing Dock . ?
Damn. That's not a lag. That's how Cinebench renders the project. The speed depends on the number of cores which is related to the CPU. I thought you mean system is lagging.
Acceleration seems to be enabled. Now if you have data on the system, back it up and perform a clean install. You must erase the whole drive, not any partition. Once done, check if you still get panics.
I have a new Nvme drive I'm going to load only Sonoma on, start fresh with this EFI & Config Settings. but at the moment I'm still having crashes.
I feel like the system is getting slower.
from Monterey to Sonoma my Geekbench score has dropped 2,558
and Cinebench has dropped 2,000
I've re-ran the CPU FriendFriend . selecting performance.
Edit: also tried with/with out, and with / with out CPU topography rebuild
Coming from a 27" iMac 14,1 this Hackintosh feels about the same.. Performance wise.
I guess I expected blazing fast performance from this build on z790 / 12th Gen i9
Crash: Browsing the web
Date/Time: 2023-10-24 08:12:20.672 -0400
End time: 2023-10-24 08:14:40.077 -0400
OS Version: macOS 14.0 (Build 23A344)
Architecture: x86_64h
Report Version: 44
Incident Identifier: 26357C45-FB67-47CA-A068-AF4C11270920
Data Source: Microstackshots
Shared Cache: 62BFF6A2-85E3-3E99-AA9C-94B8C34708C1 slid base address 0x7ff80992d000, slide 0x992d000
Command: com.apple.WebKit.WebContent
Path: /Volumes/VOLUME/*/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Identifier: com.apple.WebKit.WebContent
Version: 19616 (19616.1.27.211.1)
Build Version: 1
Project Name: WebKit
Source Version: 7616001027211001
Resource Coalition ID: 475
Parent: UNKNOWN [1]
PID: 625
Event: cpu usage
Action taken: none
CPU: 90 seconds cpu time over 139 seconds (65% cpu average), exceeding limit of 50% cpu over 180 seconds
CPU limit: 90s
Limit duration: 180s
CPU used: 90s
CPU duration: 139s
Duration: 139.40s
Duration Sampled: 27.05s
Steps: 28
Hardware model: MacPro7,1
Active cpus: 24
HW page size: 4096
VM page size: 4096
Boot args: keepsyms=1 debug=0x100 agdpmod=pikera -wegnoigpu
Fan speed: 0 rpm
Advisory levels: Battery -> 3, User -> 2, ThermalPressure -> 0, Combined -> 2
Free disk space: 375.71 GB/931.32 GB, low space threshold 3072 MB
Vnodes Available: 77.70% (204477/263168, 123829 allocated)
Preferred User Language: en-US
Country Code: US
OS Cryptex File Extents: 1
Heaviest stack for the target process:
14 start + 1942 (dyld + 25510) [0x7ff8099dd3a6]
14 WebKit::XPCServiceMain(int, char const**) + 268 (WebKit + 2547986) [0x7ff90dd5b112]
14 xpc_main + 56 (libxpc.dylib + 89638) [0x7ff809a8de26]
14 _xpc_main + 259 (libxpc.dylib + 140919) [0x7ff809a9a677]
14 _xpc_objc_main + 606 (libxpc.dylib + 90627) [0x7ff809a8e203]
14 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 907915) [0x7ff80ae58a8b]
14 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 216 (Foundation + 375761) [0x7ff80add6bd1]
14 CFRunLoopRunSpecific + 557 (CoreFoundation + 500594) [0x7ff809e3f372]
14 __CFRunLoopRun + 919 (CoreFoundation + 503073) [0x7ff809e3fd21]
14 __CFRunLoopDoSources0 + 215 (CoreFoundation + 508068) [0x7ff809e410a4]
14 __CFRunLoopDoSource0 + 157 (CoreFoundation + 508633) [0x7ff809e412d9]
14 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17 (CoreFoundation + 508727) [0x7ff809e41337]
14 WTF::RunLoop::performWork(void*) + 26 (JavaScriptCore + 2068538) [0x7ff8266ed03a]
14 WTF::RunLoop::performWork() + 430 (JavaScriptCore + 2065070) [0x7ff8266ec2ae]
14 WTF::Detail::CallableWrapper<IPC::Connection::enqueueIncomingMessage(std::__1::unique_ptr<IPC::Decoder, std::__1::default_delete<IPC::Decoder>>)::$_15, void>::call() + 144 (WebKit + 10325700) [0x7ff90e4c5ec4]
14 IPC::Connection::dispatchMessage(std::__1::unique_ptr<IPC::Decoder, std::__1::default_delete<IPC::Decoder>>) + 269 (WebKit + 10316439) [0x7ff90e4c3a97]
14 WebKit::WebProcess::didReceiveMessage(IPC::Connection&, IPC::Decoder&) + 28 (WebKit + 7114730) [0x7ff90e1b5fea]
14 IPC::MessageReceiverMap::dispatchMessage(IPC::Connection&, IPC::Decoder&) + 223 (WebKit + 10332541) [0x7ff90e4c797d]
14 WebKit::RemoteObjectRegistry::didReceiveMessage(IPC::Connection&, IPC::Decoder&) + 204 (WebKit + 1879522) [0x7ff90dcb7de2]
14 -[_WKRemoteObjectRegistry _invokeMethod:] + 459 (WebKit + 2309408) [0x7ff90dd20d20]
14 -[NSInvocation invoke] + 302 (CoreFoundation + 383958) [0x7ff809e22bd6]
14 __invoking___ + 140 (CoreFoundation + 384300) [0x7ff809e22d2c]
14 ??? (SafariSharedUI + 874642) [0x7ff926c66892]
14 ??? (SafariSharedUI + 873695) [0x7ff926c664df]
13 ??? (SafariSharedUI + 871663) [0x7ff926c65cef]
10 ??? (SafariSharedUI + 871041) [0x7ff926c65a81]
7 ??? (SafariShared + 1155214) [0x7ff90f4b808e]
7 ??? (SafariShared + 1155383) [0x7ff90f4b8137]
7 JSObjectCallAsFunction + 425 (JavaScriptCore + 234249) [0x7ff82652d309]
7 JSC::Interpreter::executeCall(JSC::JSObject*, JSC::CallData const&, JSC::JSValue, JSC::ArgList const&) + 516 (JavaScriptCore + 16139892) [0x7ff827458674]
7 vmEntryToJavaScript + 213 (JavaScriptCore + 5604598) [0x7ff826a4c4f6]
4 ??? [0x4ea915d1c1d4]
4 ??? [0x4ea917539f9b]
4 ??? [0x4ea915c0c1b8]
2 JSC::globalFuncDateTimeFormat(JSC::JSGlobalObject*, JSC::CallFrame*) + 102 (JavaScriptCore + 19229734) [0x7ff82774ac26]
1 JSC::IntlDateTimeFormat::initializeDateTimeFormat(JSC::JSGlobalObject*, JSC::JSValue, JSC::JSValue) + 27717 (JavaScriptCore + 5361045) [0x7ff826a10d95]
1 udat_open + 324 (libicucore.A.dylib + 2060117) [0x7ff80cebcf55]
1 icu::SimpleDateFormat::SimpleDateFormat(icu::UnicodeString const&, icu::Locale const&, UErrorCode&) + 213 (libicucore.A.dylib + 1862625) [0x7ff80ce8cbe1]
1 icu::SimpleDateFormat::initializeCalendar(icu::TimeZone*, icu::Locale const&, UErrorCode&) + 63 (libicucore.A.dylib + 1859651) [0x7ff80ce8c043]
1 icu:📆:createInstance(icu::TimeZone*, icu::Locale const&, UErrorCode&) + 38 (libicucore.A.dylib + 903048) [0x7ff80cda2788]
1 ??? (libicucore.A.dylib + 903510) [0x7ff80cda2956]
1 icu::Locale::~Locale() + 53 (libicucore.A.dylib + 115943) [0x7ff80cce24e7]
1 free_tiny + 6 (libsystem_malloc.dylib + 21753) [0x7ff809b874f9]
Powerstats for: com.apple.WebKit.WebContent (com.apple.WebKit.WebContent) [625]
UUID: 3C5654F1-6A87-3265-B52C-0C3F42C32474
Build Version: 1
Parent: UNKNOWN [1]
UID: 501
Sudden Term: Tracked (allows idle exit)
Footprint: 2337.62 MB -> 6456.03 MB (+4118.41 MB)
Pageins: 1 pages
Start time: 2023-10-24 08:14:12.638 -0400
End time: 2023-10-24 08:14:39.684 -0400
Num samples: 14 (50%)
Primary state: 12 samples Non-Frontmost App, Non-Suppressed, User mode, Effective Thread QoS Background, Requested Thread QoS User Interactive, Override Thread QoS Unspecified
User Activity: 0 samples Idle, 14 samples Active
Power Source: 0 samples on Battery, 14 samples on AC
1 JSC::IntlDateTimeFormat::initializeDateTimeFormat(JSC::JSGlobalObject*, JSC::JSValue, JSC::JSValue) + 24355 (JavaScriptCore + 5357683) [0x7ff826a10073]
1 JSC::IntlCache::getBestDateTimePattern(WTF::CString const&, char16_t const*, unsigned int, UErrorCode&) + 141 (JavaScriptCore + 18621885) [0x7ff8276b65bd]
1 udatpg_getBestPatternWithOptions + 195 (libicucore.A.dylib + 2070359) [0x7ff80cebf757]
1 icu::DateTimePatternGenerator::getBestPattern(icu::UnicodeString const&, UDateTimePatternMatchOptions, UErrorCode&) + 454 (libicucore.A.dylib + 1242152) [0x7ff80cdf5428]
1 icu::DateTimePatternGenerator::getBestRaw(icu::DateTimeMatcher&, int, icu::DistanceInfo*, UErrorCode&, icu::PtnSkeleton const**) + 514 (libicucore.A.dylib + 1244528) [0x7ff80cdf5d70]
1 ??? (libicucore.A.dylib + 1250699) [0x7ff80cdf758b]
1 JSC::globalFuncDateTimeFormat(JSC::JSGlobalObject*, JSC::CallFrame*) + 242 (JavaScriptCore + 19229874) [0x7ff82774acb2]
1 JSC::IntlDateTimeFormat::format(JSC::JSGlobalObject*, double) const + 131 (JavaScriptCore + 5389875) [0x7ff826a17e33]
1 udat_format + 307 (libicucore.A.dylib + 2060792) [0x7ff80cebd1f8]
1 icu::DateFormat::format(double, icu::UnicodeString&, icu::FieldPosition&) const + 110 (libicucore.A.dylib + 1065256) [0x7ff80cdca128]
1 icu::SimpleDateFormat::format(icu::Calendar&, icu::UnicodeString&, icu::FieldPosition&) const + 86 (libicucore.A.dylib + 1868774) [0x7ff80ce8e3e6]
1 icu::SimpleDateFormat::_format(icu::Calendar&, icu::UnicodeString&, icu::FieldPositionHandler&, UErrorCode&) const + 415 (libicucore.A.dylib + 1869215) [0x7ff80ce8e59f]
1 icu::SimpleDateFormat::subFormat(icu::UnicodeString&, char16_t, int, UDisplayContext, int, char16_t, icu::FieldPositionHandler&, icu::Calendar&, UErrorCode&) const + 3192 (libicucore.A.dylib + 1872842) [0x7ff80ce8f3ca]
1 icu::SimpleDateFormat::zeroPaddingNumber(icu::NumberFormat const*, icu::UnicodeString&, int, int, int) const + 479 (libicucore.A.dylib + 1876619) [0x7ff80ce9028b]
1 icu::number::LocalizedNumberFormatter::formatImpl(icu::number::impl::UFormattedNumberData*, UErrorCode&) const + 127 (libicucore.A.dylib + 1460579) [0x7ff80ce2a963]
1 ??? (libicucore.A.dylib + 1463443) [0x7ff80ce2b493]
1 ??? (libicucore.A.dylib + 1466092) [0x7ff80ce2beec]
1 icu::DecimalFormatSymbols::initialize(icu::Locale const&, UErrorCode&, signed char, icu::NumberingSystem const*, bool) + 1597 (libicucore.A.dylib + 1075397) [0x7ff80cdcc8c5]
1 ??? (libicucore.A.dylib + 730654) [0x7ff80cd7861e]
1 ??? (libicucore.A.dylib + 743337) [0x7ff80cd7b7a9]
1 ??? (libicucore.A.dylib + 745730) [0x7ff80cd7c102]
1 icu::CharString::append(char const*, int, UErrorCode&) + 208 (libicucore.A.dylib + 32592) [0x7ff80cccdf50]
1 _platform_memmove$VARIANT$Haswell + 163 (libsystem_platform.dylib + 2691) [0x7ff809d90a83]
1 JSC::globalFuncDateTimeFormat(JSC::JSGlobalObject*, JSC::CallFrame*) + 50 (JavaScriptCore + 19229682) [0x7ff82774abf2]
1 JSC::IntlDateTimeFormat::create(JSC::VM&, JSC::Structure*) + 220 (JavaScriptCore + 5330060) [0x7ff826a0948c]
1 JSC::LocalAllocator::allocateSlowCase(JSC::Heap&, unsigned long, JSC::GCDeferralContext*, JSC::AllocationFailureMode) + 300 (JavaScriptCore + 14641836) [0x7ff8272eaaac]
1 JSC::MarkedBlock::Handle::sweep(JSC::FreeList*) + 773 (JavaScriptCore + 14662453) [0x7ff8272efb35]
1 JSC::IsoHeapCellType::finishSweep(JSC::MarkedBlock::Handle&, JSC::FreeList*) const + 537 (JavaScriptCore + 14626025) [0x7ff8272e6ce9]
1 icu::SimpleDateFormat::~SimpleDateFormat() + 14 (libicucore.A.dylib + 1856264) [0x7ff80ce8b308]
1 icu::SimpleDateFormat::~SimpleDateFormat() + 91 (libicucore.A.dylib + 1855925) [0x7ff80ce8b1b5]
1 icu::SimpleDateFormat::freeFastNumberFormatters() + 30 (libicucore.A.dylib + 1856090) [0x7ff80ce8b25a]
1 icu::number::LocalizedNumberFormatter::~LocalizedNumberFormatter() + 30 (libicucore.A.dylib + 1459496) [0x7ff80ce2a528]
1 ??? (libicucore.A.dylib + 1461921) [0x7ff80ce2aea1]
1 ??? (libicucore.A.dylib + 1519870) [0x7ff80ce390fe]
1 icu::number::impl::AdoptingModifierStore::~AdoptingModifierStore() + 41 (libicucore.A.dylib + 1504595) [0x7ff80ce35553]
1 free_tiny + 105 (libsystem_malloc.dylib + 21852) [0x7ff809b8755c]
1 <Frontmost App, Effective Thread QoS User Interactive>
1 ??? [0x4ea915dc0cd3]
1 ??? [0x4ea91753e19b]
1 ??? [0x4ea915c0c1b8]
1 icu::DecimalFormatSymbols::initialize(icu::Locale const&, UErrorCode&, signed char, icu::NumberingSystem const*, bool) + 1174 (libicucore.A.dylib + 1074974) [0x7ff80cdcc71e]
1 ures_getAllItemsWithFallback + 193 (libicucore.A.dylib + 728345) [0x7ff80cd77d19]
1 ??? (libicucore.A.dylib + 728650) [0x7ff80cd77e4a]
1 ??? (libicucore.A.dylib + 1081049) [0x7ff80cdcded9]
1 ??? (libicucore.A.dylib + 1081296) [0x7ff80cdcdfd0]
1 icu::UnicodeString::copyFrom(icu::UnicodeString const&, signed char) + 346 (libicucore.A.dylib + 694596) [0x7ff80cd6f944]
1 u_memcpy + 26 (libicucore.A.dylib + 796414) [0x7ff80cd886fe]
1 _platform_memmove$VARIANT$Haswell + 218 (libsystem_platform.dylib + 2746) [0x7ff809d90aba]
1 ??? [0x4ea915d55fd3]
1 ??? [0x4ea915dceb9c]
1 JSC::globalFuncDateTimeFormat(JSC::JSGlobalObject*, JSC::CallFrame*) + 102 (JavaScriptCore + 19229734) [0x7ff82774ac26]
1 udat_open + 565 (libicucore.A.dylib + 2060358) [0x7ff80cebd046]
1 icu::TimeZone::createTimeZone(icu::UnicodeString const&) + 24 (libicucore.A.dylib + 1912662) [0x7ff80ce98f56]
1 ??? (libicucore.A.dylib + 1923634) [0x7ff80ce9ba32]
1 icu::OlsonTimeZone::OlsonTimeZone(UResourceBundle const*, UResourceBundle const*, icu::UnicodeString const&, UErrorCode&) + 1102 (libicucore.A.dylib + 1619428) [0x7ff80ce515e4]
1 icu::TimeZone::loadRule(UResourceBundle const*, icu::UnicodeString const&, UResourceBundle*, UErrorCode&) + 133 (libicucore.A.dylib + 1911945) [0x7ff80ce98c89]
1 ures_getByKey + 184 (libicucore.A.dylib + 729202) [0x7ff80cd78072]
1 ??? (libicucore.A.dylib + 739370) [0x7ff80cd7a82a]
1 ??? (libicucore.A.dylib + 723121) [0x7ff80cd768b1]
1 ??? [0x4ea915d4ddd3]
1 ??? [0x4ea915d93d9c]
1 icu::DateFormat::format(double, icu::UnicodeString&, icu::FieldPosition&) const + 120 (libicucore.A.dylib + 1065266) [0x7ff80cdca132]
1 icu::GregorianCalendar::~GregorianCalendar() + 14 (libicucore.A.dylib + 1291978) [0x7ff80ce016ca]
1 icu:📆:~Calendar() + 37 (libicucore.A.dylib + 902513) [0x7ff80cda2571]
1 icu::OlsonTimeZone::~OlsonTimeZone() + 14 (libicucore.A.dylib + 1620712) [0x7ff80ce51ae8]
1 icu::OlsonTimeZone::~OlsonTimeZone() + 42 (libicucore.A.dylib + 1620444) [0x7ff80ce519dc]
1 free_tiny + 164 (libsystem_malloc.dylib + 21911) [0x7ff809b87597]
2 ??? (SafariShared + 1155149) [0x7ff90f4b804d]
1 ??? (SafariShared + 1154234) [0x7ff90f4b7cba]
1 ??? (SafariShared + 1157521) [0x7ff90f4b8991]
1 +[JSValue valueWithObject:inContext:] + 28 (JavaScriptCore + 1584348) [0x7ff826676cdc]
1 objectToValue + 832 (JavaScriptCore + 6618832) [0x7ff826b43ed0]
1 -[__NSDictionaryM keyEnumerator] + 36 (CoreFoundation + 438757) [0x7ff809e301e5]
1 __CFAllocateObject + 11 (CoreFoundation + 15577) [0x7ff809dc8cd9]
1 class_createInstance + 52 (libobjc.A.dylib + 26359) [0x7ff80999b6f7]
1 szone_malloc_should_clear + 65 (libsystem_malloc.dylib + 7226) [0x7ff809b83c3a]
1 tiny_malloc_should_clear + 1093 (libsystem_malloc.dylib + 12579) [0x7ff809b85123]
1 ??? (SafariShared + 1153937) [0x7ff90f4b7b91]
1 -[NSObject conformsToProtocol:] + 47 (libobjc.A.dylib + 54231) [0x7ff8099a23d7]
1 class_conformsToProtocol + 363 (libobjc.A.dylib + 54631) [0x7ff8099a2567]
1 protocol_conformsToProtocol_nolock(protocol_t*, protocol_t*) + 72 (libobjc.A.dylib + 54904) [0x7ff8099a2678]
1 ??? (SafariShared + 1155165) [0x7ff90f4b805d]
1 objectToValue + 1492 (JavaScriptCore + 6619492) [0x7ff826b44164]
1 JSObjectSetProperty + 62 (JavaScriptCore + 263966) [0x7ff82653471e]
1 JSC::JSLockHolder::JSLockHolder(JSC::VM&) + 18 (JavaScriptCore + 19478258) [0x7ff8277876f2]
2 ??? (SafariSharedUI + 871041) [0x7ff926c65a81]
2 ??? (SafariShared + 1155214) [0x7ff90f4b808e]
2 ??? (SafariShared + 1155383) [0x7ff90f4b8137]
2 JSObjectCallAsFunction + 425 (JavaScriptCore + 234249) [0x7ff82652d309]
2 JSC::Interpreter::executeCall(JSC::JSObject*, JSC::CallData const&, JSC::JSValue, JSC::ArgList const&) + 516 (JavaScriptCore + 16139892) [0x7ff827458674]
2 vmEntryToJavaScript + 213 (JavaScriptCore + 5604598) [0x7ff826a4c4f6]
1 ??? [0x4ea915dd02d3]
1 ??? [0x4ea915e2029c]
1 JSC::IntlDateTimeFormat::initializeDateTimeFormat(JSC::JSGlobalObject*, JSC::JSValue, JSC::JSValue) + 28035 (JavaScriptCore + 5361363) [0x7ff826a10ed3]
1 icu::GregorianCalendar::setGregorianChange(double, UErrorCode&) + 240 (libicucore.A.dylib + 1292770) [0x7ff80ce019e2]
1 icu::GregorianCalendar::GregorianCalendar(icu::TimeZone const&, UErrorCode&) + 41 (libicucore.A.dylib + 1290725) [0x7ff80ce011e5]
1 icu:📆:setWeekData(icu::Locale const&, char const*, UErrorCode&) + 912 (libicucore.A.dylib + 901784) [0x7ff80cda2298]
1 ??? (libicucore.A.dylib + 730966) [0x7ff80cd78756]
1 <Kernel mode>
1 JSC::IntlDateTimeFormat::initializeDateTimeFormat(JSC::JSGlobalObject*, JSC::JSValue, JSC::JSValue) + 4718 (JavaScriptCore + 5338046) [0x7ff826a0b3be]
1 JSC::resolveLocale(JSC::JSGlobalObject*, WTF::HashSet<WTF::String, WTF::DefaultHash<WTF::String>, WTF::HashTraits<WTF::String>, WTF::MemoryCompactLookupOnlyRobinHoodHashTableTraits> const&, WTF::Vector<WTF::String, 0ul, WTF::CrashOnOverflow, 16ul, WTF::FastMalloc> const&, JSC::LocaleMatcher, std::__1::array<std::__1::optional<WTF::String>, 6ul> const&, std::initializer_list<JSC::RelevantExtensionKey>, WTF::Vector<WTF::String, 0ul, WTF::CrashOnOverflow, 16ul, WTF::FastMalloc> (*)(WTF::String const&, JSC::RelevantExtensionKey)) + 262 (JavaScriptCore + 18731382) [0x7ff8276d1176]
1 JSC::IntlDateTimeFormat::localeData(WTF::String const&, JSC::RelevantExtensionKey) + 1634 (JavaScriptCore + 5331986) [0x7ff826a09c12]
1 ulist_close_keyword_values_iterator + 23 (libicucore.A.dylib + 589884) [0x7ff80cd5603c]
1 ulist_deleteList + 54 (libicucore.A.dylib + 589834) [0x7ff80cd5600a]
1 free_tiny + 526 (libsystem_malloc.dylib + 22273) [0x7ff809b87701]
1 tiny_free_no_lock + 2014 (libsystem_malloc.dylib + 24591) [0x7ff809b8800f]
1 ??? (SafariSharedUI + 871663) [0x7ff926c65cef]
1 ??? (SafariSharedUI + 871041) [0x7ff926c65a81]
1 ??? (SafariShared + 1155214) [0x7ff90f4b808e]
1 ??? (SafariShared + 1155383) [0x7ff90f4b8137]
1 JSObjectCallAsFunction + 425 (JavaScriptCore + 234249) [0x7ff82652d309]
1 JSC::Interpreter::executeCall(JSC::JSObject*, JSC::CallData const&, JSC::JSValue, JSC::ArgList const&) + 516 (JavaScriptCore + 16139892) [0x7ff827458674]
1 vmEntryToJavaScript + 213 (JavaScriptCore + 5604598) [0x7ff826a4c4f6]
1 ??? [0x4ea915ec84d3]
1 ??? [0x4ea915ec8c9c]
1 icu::SimpleDateFormat::SimpleDateFormat(icu::UnicodeString const&, icu::Locale const&, UErrorCode&) + 245 (libicucore.A.dylib + 1862657) [0x7ff80ce8cc01]
1 icu::SimpleDateFormat::initialize(icu::Locale const&, UErrorCode&) + 715 (libicucore.A.dylib + 1860385) [0x7ff80ce8c321]
1 icu::SimpleDateFormat::initFastNumberFormatters(UErrorCode&) + 107 (libicucore.A.dylib + 1865121) [0x7ff80ce8d5a1]
1 ??? (libicucore.A.dylib + 1875979) [0x7ff80ce9000b]
1 ??? (libicucore.A.dylib + 1455572) [0x7ff80ce295d4]
1 icu::number::Scale::Scale(icu::number::Scale const&) + 0 (libicucore.A.dylib + 1510960) [0x7ff80ce36e30]
1 objc_msgSend + 50 (libobjc.A.dylib + 26930) [0x7ff80999b932]
Binary Images:
0x10460d000 - 0x104618fff com.apple.WebKit.WebContent 19616 (19616.1.27.211.1) <3C5654F1-6A87-3265-B52C-0C3F42C32474> /Volumes/VOLUME/*/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
0x7ff809995000 - 0x7ff8099d6fc0 libobjc.A.dylib (906) <CB7AC98C-B998-3A03-A07D-6125DE3391D1> /usr/lib/libobjc.A.dylib
0x7ff8099d7000 - 0x7ff809a732ff dyld (1122.1) <1289B60A-4980-342D-B1A4-250BBEE392F1> /usr/lib/dyld
0x7ff809a78000 - 0x7ff809abbffa libxpc.dylib (2679.0.25) <C8A6CABB-1668-3673-95A5-FB0D51156E24> /usr/lib/system/libxpc.dylib
0x7ff809b82000 - 0x7ff809bbaff7 libsystem_malloc.dylib (474.0.13) <E2CE4C5D-9CC9-38BD-9110-055E20F88487> /usr/lib/system/libsystem_malloc.dylib
0x7ff809d90000 - 0x7ff809d99fff libsystem_platform.dylib (306.0.1) <D160C87C-BE22-319E-8300-4681DCE19C96> /usr/lib/system/libsystem_platform.dylib
0x7ff809dc5000 - 0x7ff80a25effc com.apple.CoreFoundation 6.9 (2048.1.403) <9DAA29F3-FE48-39A9-A70D-1E0FD4750372> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff80ad7b000 - 0x7ff80b9b8ffb com.apple.Foundation 6.9 (2048.1.403) <097DC90A-7059-3135-8FCB-74DE290206A1> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7ff80ccc6000 - 0x7ff80cf5afff libicucore.A.dylib (72122) <B01ABAD9-D44B-3EA2-B03D-06244514B40B> /usr/lib/libicucore.A.dylib
0x7ff8264f4000 - 0x7ff8280dbffa com.apple.JavaScriptCore 19616 (19616.1.27.211.1) <9802EB3C-A186-389E-98C1-4DD448F69AE2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7ff90daed000 - 0x7ff90e620ffe com.apple.WebKit 19616 (19616.1.27.211.1) <EEDB41A8-A617-3B31-B409-FB109319DE0D> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7ff90f39e000 - 0x7ff90f64dffe com.apple.Safari.Shared 19616 (19616.1.27.211.1) <89EECCBD-66E8-32A1-9E38-5BB92C0EFED6> /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/SafariShared
0x7ff926b91000 - 0x7ff926df8ff8 com.apple.Safari.Shared.UI 19616 (19616.1.27.211.1) <04DBF66B-9E01-3A06-92BA-B2F496DFBFEF> /System/Library/PrivateFrameworks/SafariSharedUI.framework/Versions/A/SafariSharedUI
Powerstats for: OpenRGB
UUID: 2E2DB0E4-0414-3942-BA68-51C424FE2E0A
Path: /Applications/OpenRGB.app/Contents/MacOS/OpenRGB
Identifier: com.yourcompany.OpenRGB
Is First Party: No
Resource Coalition ID: 553
Start time: 2023-10-24 08:14:13.640 -0400
End time: 2023-10-24 08:14:31.671 -0400
Num samples: 4 (14%)
Primary state: 3 samples Non-Frontmost App, Suppressed, Kernel mode, Effective Thread QoS Default, Requested Thread QoS Default, Override Thread QoS Unspecified
User Activity: 0 samples Idle, 4 samples Active
Power Source: 0 samples on Battery, 4 samples on AC
4 thread_start + 15 (libsystem_pthread.dylib + 7083) [0x7ff809d61bab]
4 _pthread_start + 99 (libsystem_pthread.dylib + 25090) [0x7ff809d66202]
3 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (RGBController::*)(), RGBController*>>(void*) + 62 (OpenRGBVisualMapPlugin_0.9_MacOS_Intel_bbf30c4.dylib + 39358) [0x11a3b49be]
3 RGBController::DeviceCallThreadFunction() + 80 (OpenRGBVisualMapPlugin_0.9_MacOS_Intel_bbf30c4.dylib + 38464) [0x11a3b4640]
3 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 73 (libc++.1.dylib + 122068) [0x7ff809caacd4]
2 nanosleep + 91 (libsystem_c.dylib + 63109) [0x7ff809c14685]
2 clock_get_time + 89 (libsystem_kernel.dylib + 24431) [0x7ff809d2af6f]
2 mach_msg2_trap + 10 (libsystem_kernel.dylib + 6702) [0x7ff809d26a2e]
1 __semwait_signal + 10 (libsystem_kernel.dylib + 17570) [0x7ff809d294a2]
1 ??? (OpenRGB + 5174574) [0x10c13352e]
1 RGBController::DeviceCallThreadFunction() + 80 (OpenRGB + 5173680) [0x10c1331b0]
1 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>> const&) + 73 (libc++.1.dylib + 122068) [0x7ff809caacd4]
1 <User mode>
Binary Images:
0x10bc44000 - 0x10c28ffff com.yourcompany.OpenRGB (0) <2E2DB0E4-0414-3942-BA68-51C424FE2E0A> /Applications/OpenRGB.app/Contents/MacOS/OpenRGB
0x11a3ab000 - 0x11a41afff OpenRGBVisualMapPlugin_0.9_MacOS_Intel_bbf30c4.dylib (0) <7D003520-07E5-3EAB-BB20-3DF3DCAE0FEA> /Users/USER/*/OpenRGBVisualMapPlugin_0.9_MacOS_Intel_bbf30c4.dylib
0x7ff809c05000 - 0x7ff809c8cfff libsystem_c.dylib (1583.0.14) <3E9A5BFA-50C0-3A96-9291-4826C62D1182> /usr/lib/system/libsystem_c.dylib
0x7ff809c8d000 - 0x7ff809d0bfff libc++.1.dylib (1600.151) <1D0EB230-4AAE-3D78-94C8-3592266667F6> /usr/lib/libc++.1.dylib
0x7ff809d25000 - 0x7ff809d5fff7 libsystem_kernel.dylib (10002.1.13) <3690C1FC-599F-39FF-BBDB-85422E9A996C> /usr/lib/system/libsystem_kernel.dylib
0x7ff809d60000 - 0x7ff809d6bfff libsystem_pthread.dylib (519) <33C43114-85F0-3F32-86D7-8E6A2403D38C> /usr/lib/system/libsystem_pthread.dylib
Powerstats for: WindowServer
UUID: 4ECCB79C-0EEB-352E-8E81-63F068191853
Path: /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
Codesigning ID: com.apple.WindowServer
Resource Coalition ID: 141
On Behalf Of: 1 sample WindowServer [156]
Start time: 2023-10-24 08:14:19.648 -0400
End time: 2023-10-24 08:14:26.660 -0400
Primary state: 4 samples Non-Frontmost App, Non-Suppressed, User mode, Effective Thread QoS Unspecified, Requested Thread QoS Unspecified, Override Thread QoS Unspecified
3 start_wqthread + 15 (libsystem_pthread.dylib + 7063) [0x7ff809d61b97]
3 _pthread_wqthread + 327 (libsystem_pthread.dylib + 11335) [0x7ff809d62c47]
2 _dispatch_workloop_worker_thread + 451 (libdispatch.dylib + 78845) [0x7ff809bce3fd]
1 _dispatch_root_queue_drain_deferred_wlh + 271 (libdispatch.dylib + 80622) [0x7ff809bceaee]
1 _dispatch_workloop_invoke + 803 (libdispatch.dylib + 44864) [0x7ff809bc5f40]
1 _dispatch_lane_invoke + 377 (libdispatch.dylib + 41216) [0x7ff809bc5100]
1 _dispatch_lane_serial_drain + 387 (libdispatch.dylib + 38075) [0x7ff809bc44bb]
1 _dispatch_source_invoke + 2076 (libdispatch.dylib + 91896) [0x7ff809bd16f8]
1 _dispatch_continuation_pop + 523 (libdispatch.dylib + 24775) [0x7ff809bc10c7]
1 _dispatch_client_callout + 8 (libdispatch.dylib + 13722) [0x7ff809bbe59a]
1 dispatch_mig_server + 361 (libdispatch.dylib + 121337) [0x7ff809bd89f9]
1 _IODispatchCalloutWithDispatch + 33 (IOKit + 23378) [0x7ff80d2e6b52]
1 IODispatchCalloutFromCFMessage + 351 (IOKit + 23742) [0x7ff80d2e6cbe]
1 _ioAccelDisplayPipeTransactionNotifyCallback + 179 (IOAccelerator + 25050) [0x7ff8141a01da]
1 invocation function for block in IOPresentmentDisplayPipe::DisplayPipeDoCallback(void (*)(void*, __CFString const*, unsigned long*, unsigned int), void*, __IOPresentmentTransaction*, unsigned long, unsigned long, unsigned long, unsigned long) + 272 (IOPresentment + 95347) [0x7ff819364473]
1 CFRetain + 0 (CoreFoundation + 15691) [0x7ff809dc8d4b]
1 _dispatch_workloop_invoke + 0 (libdispatch.dylib + 44061) [0x7ff809bc5c1d]
1 _dispatch_workloop_worker_thread + 201 (libdispatch.dylib + 78595) [0x7ff809bce303]
1 start + 1942 (dyld + 25510) [0x7ff8099dd3a6]
1 ??? (WindowServer + 13452) [0x10af8d48c]
1 SLXServer + 1265 (SkyLight + 3553074) [0x7ff80f6fa732]
1 server_loop + 98 (SkyLight + 3553496) [0x7ff80f6fa8d8]
1 CGXRunOneServicesPass + 1696 (SkyLight + 3551025) [0x7ff80f6f9f31]
1 post_port_data + 269 (SkyLight + 3551718) [0x7ff80f6fa1e6]
1 block_hoist_notification_handler(unsigned int, mach_msg_header_t*, void*) + 17 (SkyLight + 337664) [0x7ff80f3e9700]
1 block_hoist_invoke_blocks(WSMainThreadBlockHoist*, bool) + 334 (SkyLight + 338002) [0x7ff80f3e9852]
1 free_small + 611 (libsystem_malloc.dylib + 17792) [0x7ff809b86580]
1 small_free_list_remove_ptr_no_clear + 673 (libsystem_malloc.dylib + 29012) [0x7ff809b89154]
1 <on behalf of WindowServer [156]>
Binary Images:
0x10af8a000 - 0x10af99fff WindowServer (841.8) <4ECCB79C-0EEB-352E-8E81-63F068191853> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
0x7ff809bbb000 - 0x7ff809c01ffd libdispatch.dylib (1462.0.4) <5203F33A-D525-32A5-BD79-2CCE93555AEE> /usr/lib/system/libdispatch.dylib
0x7ff80d2e1000 - 0x7ff80d3a3ff6 com.apple.framework.IOKit 2.0.2 (100065.1.1) <0C6A179C-C09D-3BE9-9EFC-9E870D70EDC0> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7ff80f397000 - 0x7ff80f7e9ff2 com.apple.SkyLight 1.600.0 (841.8) <56041E50-BA02-3CA4-8244-97E80B682C81> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7ff81419a000 - 0x7ff8141a2ff7 com.apple.IOAccelerator 481.0.1 (481.0.1) <0BDA3683-ED59-3DEB-8EDC-731741DDD213> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7ff81934d000 - 0x7ff819368fff com.apple.IOPresentment 62 (37) <BAE1A3E8-DD11-38CA-8FE3-00F448CD8321> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
That's why recommended to do a clean install. xD
I've re-rant the CPU FriendFriend . selecting performance.
Try without that first. Maybe that's what giving you kernel panic. The reason why you had bit more score is because of the XcpmForceBoost but keep in mind what i mentioned earlier.
If you were using an SSD on that iMac, you won't notice much in general operation. But if you run Cinebench on your old iMac, that would be like 5-7K. 12th Gen i9 has a score of 26K which is what you're getting. So i don't see any drop in performance or something like that.
Report Version: 44
Build Version: 1
Parent: UNKNOWN [1]
PID: 625
Event: cpu usage
Action taken: none
CPU limit: 90s
CPU used: 90s
CPU duration: 139s
Duration: 139.40s
Steps: 28
Active cpus: 24
HW page size: 4096
VM page size: 4096
Fan speed: 0 rpm
Country Code: US
Build Version: 1
Parent: UNKNOWN [1]
UID: 501
Pageins: 1 pages
1 icu::DateTimePatternGenerator::getBestRaw(icu::DateTimeMatcher&, int, icu::DistanceInfo*, UErrorCode&, icu::ptnSkeleton const**) + 514 (libicucore.A.dylib + 1244528) [0x7ff80cdf5d70]
1 <Kernel mode>
1 JSC::resolveLocale(JSC::JSGlobalObject*, WTF::HashSet<WTF::String, WTF::DefaultHash<WTF::String>, WTF::HashTraits<WTF::String>, WTF::MemoryCompactLookupOnlyRobinHoodHashTableTraits> const&, WTF::Vector<WTF::String, 0ul, WTF::CrashOnOverflow, 16ul, WTF::FastMalloc> const&, JSC::LocaleMatcher, std::__1::array<std::__1::eek:ptional<WTF::String>, 6ul> const&, std::initializer_list<JSC::RelevantExtensionKey>, WTF::Vector<WTF::String, 0ul, WTF::CrashOnOverflow, 16ul, WTF::FastMalloc> (*)(WTF::String const&, JSC::RelevantExtensionKey)) + 262 (JavaScriptCore + 18731382) [0x7ff8276d1176]
Binary Images:
Is First Party: No
1 <User mode>
Binary Images:
Binary Images:
Wrong SMBIOS selection. Use iMacPro1,1. Turn off XMP in BIOS. Do a clean install. What's the boot drive model?
Crash Changing File extension:
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Translated Report (Full Report Below)
Process: mds_stores [15882]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
Identifier: mds_stores
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 0
Date/Time: 2023-10-24 07:56:04.6840 -0400
OS Version: macOS 14.0 (23A344)
Report Version: 12
Anonymous UUID: 49D02254-34C1-C565-E1BF-2D2ABB62978E
Time Awake Since Boot: 42000 seconds
System Integrity Protection: enabled
Crashed Thread: 21 Dispatch queue: */0
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000bad
Exception Codes: 0x0000000000000001, 0x0000000000000bad
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [15882]
VM Region Info: 0xbad is not in any region. Bytes before following region: 140737488278611
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
shared memory 7ffffffee000-7ffffffef000 [ 4K] r-x/r-x SM=SHM
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x7ff81a045a2e mach_msg2_trap + 10
1 libsystem_kernel.dylib 0x7ff81a053e4a mach_msg2_internal + 84
2 libsystem_kernel.dylib 0x7ff81a04cb6e mach_msg_overwrite + 653
3 libsystem_kernel.dylib 0x7ff81a045d1f mach_msg + 19
4 CoreFoundation 0x7ff81a160475 __CFRunLoopServiceMachPort + 143
5 CoreFoundation 0x7ff81a15eee5 __CFRunLoopRun + 1371
6 CoreFoundation 0x7ff81a15e372 CFRunLoopRunSpecific + 557
7 mds_stores 0x10e477dda 0x10e472000 + 24026
8 dyld 0x7ff819cfc3a6 start + 1942
Thread 1:
0 libsystem_pthread.dylib 0x7ff81a080b88 start_wqthread + 0
Thread 2:: Dispatch queue: */Store
0 libsystem_kernel.dylib 0x7ff81a0485d6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff81a08576b _pthread_cond_wait + 1211
2 SpotlightIndex 0x7ff833d4cdbc si_scheduler_suspend + 266
3 SpotlightIndex 0x7ff833e2c12f si_verify + 145
4 SpotlightIndex 0x7ff833d4a5b6 compaction_runLoop + 110
5 SpotlightIndex 0x7ff833d02b6e work_fun + 859
6 libdispatch.dylib 0x7ff819eea002 _dispatch_block_async_invoke2 + 85
7 libdispatch.dylib 0x7ff819edd59a _dispatch_client_callout + 8
8 libdispatch.dylib 0x7ff819ee3668 _dispatch_lane_serial_drain + 816
9 libdispatch.dylib 0x7ff819ee4100 _dispatch_lane_invoke + 377
10 libdispatch.dylib 0x7ff819ee34bb _dispatch_lane_serial_drain + 387
11 libdispatch.dylib 0x7ff819ee4100 _dispatch_lane_invoke + 377
12 libdispatch.dylib 0x7ff819ee4f40 _dispatch_workloop_invoke + 803
13 libdispatch.dylib 0x7ff819eedaee _dispatch_root_queue_drain_deferred_wlh + 271
14 libdispatch.dylib 0x7ff819eed3fd _dispatch_workloop_worker_thread + 451
15 libsystem_pthread.dylib 0x7ff81a081c47 _pthread_wqthread + 327
16 libsystem_pthread.dylib 0x7ff81a080b97 start_wqthread + 15
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
4 SpotlightIndex 0x7ff833c61986 _handleExceptions + 120
5 libsystem_pthread.dylib 0x7ff81a085202 _pthread_start + 99
6 libsystem_pthread.dylib 0x7ff81a080bab thread_start + 15
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:: Dispatch queue: */Store
0 libsystem_kernel.dylib 0x7ff81a04882a fsync + 10
1 SpotlightIndex 0x7ff833f2decd prot_fsync + 201
2 SpotlightIndex 0x7ff833d26f37 fd_sync + 292
3 SpotlightIndex 0x7ff833d40c65 indexPerformSync + 149
4 SpotlightIndex 0x7ff833d4085e indexPerformSyncBulk + 429
5 SpotlightIndex 0x7ff833ca504b _CISyncContextSync + 1389
6 SpotlightIndex 0x7ff833d3cea1 _ContentIndexSyncIndexBulk + 319
7 SpotlightIndex 0x7ff833d3b9ff syncIndex + 2896
8 SpotlightIndex 0x7ff833d286a8 flush_runLoop + 110
9 SpotlightIndex 0x7ff833d02b6e work_fun + 859
10 libdispatch.dylib 0x7ff819eea002 _dispatch_block_async_invoke2 + 85
11 libdispatch.dylib 0x7ff819edd59a _dispatch_client_callout + 8
12 libdispatch.dylib 0x7ff819ee3668 _dispatch_lane_serial_drain + 816
13 libdispatch.dylib 0x7ff819ee4100 _dispatch_lane_invoke + 377
14 libdispatch.dylib 0x7ff819ee34bb _dispatch_lane_serial_drain + 387
15 libdispatch.dylib 0x7ff819ee4100 _dispatch_lane_invoke + 377
16 libdispatch.dylib 0x7ff819edff36 _dispatch_continuation_pop + 122
17 libdispatch.dylib 0x7ff819edf73c _dispatch_async_redirect_invoke + 710
18 libdispatch.dylib 0x7ff819eec776 _dispatch_root_queue_drain + 328
19 libdispatch.dylib 0x7ff819eecf22 _dispatch_worker_thread2 + 152
20 libsystem_pthread.dylib 0x7ff81a081c06 _pthread_wqthread + 262
21 libsystem_pthread.dylib 0x7ff81a080b97 start_wqthread + 15
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21 Crashed:: Dispatch queue: */0
0 SpotlightIndex 0x7ff833d2cd6d storageAllocOffset + 766
1 SpotlightIndex 0x7ff833d33d65 storageGrowOffset + 287
2 SpotlightIndex 0x7ff833d33936 reallocBlock + 646
3 SpotlightIndex 0x7ff833d2d64b mergeEntryFlat + 2203
4 SpotlightIndex 0x7ff833d2c765 mergeEntryFat + 1301
5 SpotlightIndex 0x7ff833d2c10a bt_mergeEntry + 138
6 SpotlightIndex 0x7ff833cc041e bt_mergeCallback + 238
7 SpotlightIndex 0x7ff833d2a831 index_FlushCache + 5857
8 SpotlightIndex 0x7ff833d3e1b0 indexPrepareForSyncBulk + 809
9 SpotlightIndex 0x7ff833ca4ce8 _CISyncContextSync + 522
10 SpotlightIndex 0x7ff833d3cea1 _ContentIndexSyncIndexBulk + 319
11 SpotlightIndex 0x7ff833d3b9ff syncIndex + 2896
12 SpotlightIndex 0x7ff833d286a8 flush_runLoop + 110
13 SpotlightIndex 0x7ff833d02b6e work_fun + 859
14 libdispatch.dylib 0x7ff819eea002 _dispatch_block_async_invoke2 + 85
15 libdispatch.dylib 0x7ff819edd59a _dispatch_client_callout + 8
16 libdispatch.dylib 0x7ff819ee3668 _dispatch_lane_serial_drain + 816
17 libdispatch.dylib 0x7ff819ee4100 _dispatch_lane_invoke + 377
18 libdispatch.dylib 0x7ff819ee34bb _dispatch_lane_serial_drain + 387
19 libdispatch.dylib 0x7ff819ee4100 _dispatch_lane_invoke + 377
20 libdispatch.dylib 0x7ff819ee4f40 _dispatch_workloop_invoke + 803
21 libdispatch.dylib 0x7ff819eedaee _dispatch_root_queue_drain_deferred_wlh + 271
22 libdispatch.dylib 0x7ff819eed3fd _dispatch_workloop_worker_thread + 451
23 libsystem_pthread.dylib 0x7ff81a081c47 _pthread_wqthread + 327
24 libsystem_pthread.dylib 0x7ff81a080b97 start_wqthread + 15
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:: Dispatch queue: */St
4 mds_stores 0x10e4aae16 0x10e472000 + 232982
5 mds_stores 0x10e49b7b2 0x10e472000 + 169906
6 SpotlightIndex 0x7ff833d3ec0c sync_datastore + 269
7 SpotlightIndex 0x7ff833ca4e86 _CISyncContextSync + 936
8 SpotlightIndex 0x7ff833d3cea1 _ContentIndexSyncIndexBulk + 319
9 SpotlightIndex 0x7ff833d3b9ff syncIndex + 2896
10 SpotlightIndex 0x7ff833d286a8 flush_runLoop + 110
11 SpotlightIndex 0x7ff833d02b6e work_fun + 859
12 libdispatch.dylib 0x7ff819eea002 _dispatch_block_async_invoke2 + 85
13 libdispatch.dylib 0x7ff819edd59a _dispatch_client_callout + 8
14 libdispatch.dylib 0x7ff819ee3668 _dispatch_lane_serial_drain + 816
16 libdispatch.dylib 0x7ff819ee34bb _dispatch_lane_serial_drain + 387
18 libdispatch.dylib 0x7ff819edff36 _dispatch_continuation_pop + 122
19 libdispatch.dylib 0x7ff819edf73c _dispatch_async_redirect_invoke + 710
20 libdispatch.dylib 0x7ff819eec776 _dispatch_root_queue_drain + 328
21 libdispatch.dylib 0x7ff819eecf22 _dispatch_worker_thread2 + 152
22 libsystem_pthread.dylib 0x7ff81a081c06 _pthread_wqthread + 262
23 libsystem_pthread.dylib 0x7ff81a080b97 start_wqthread + 15
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 21 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000001 rbx: 0x00007fd6cba20390 rcx: 0xfd852ff101da00ee rdx: 0x0000000000000000
rdi: 0x00007ff834006e41 rsi: 0x000070000968de58 rbp: 0x000070000968e720 rsp: 0x000070000968e6f0
r8: 0x0000000000000000 r9: 0x000000000000c350 r10: 0x00007000096960ac r11: 0x0000000000000202
r12: 0x000070000968e85c r13: 0x000070000968e870 r14: 0x0000000000006800 r15: 0x0000000000000005
rip: 0x00007ff833d2cd6d rfl: 0x0000000000010202 cr2: 0x0000000000000bad
Logical CPU: 8
Error Code: 0x00000006 (no mapping for user data write)
Trap Number: 14
Thread 21 instruction stream:
50 2c 00 48 8d 0d a9 87-2c 00 ba f3 02 00 00 eb P,.H....,.......
32 31 ff e8 74 a6 17 00-48 89 c3 48 85 c0 4c 8d 21..t...H..H..L.
05 ce e0 2b 00 4c 0f 45-c0 48 8d 3d a9 a0 2d 00 ...+.L.E.H.=..-.
48 8d 35 74 50 2c 00 48-8d 0d 41 51 2c 00 ba e7 H.5tP,.H..AQ,...
02 00 00 31 c0 e8 0d a7-17 00 48 89 df e8 f7 e2 ...1......H.....
2a 00 bf ff ff ff ff e8-d9 aa 1e 00 84 c0 74 10 *.............t.
[c7]04 25 ad 0b 00 00 ef-be ad de e8 5d e0 2a 00 ..%.........].*. <==
c7 04 25 00 0c 00 00 ef-be ad de e8 4d e0 2a 00 ..%.........M.*.
48 89 df 44 89 ee e8 5f-73 00 00 84 c0 74 0c 4c H..D..._s....t.L
8b 73 10 4c 89 e1 e9 de-fd ff ff 45 31 f6 e9 ed .s.L.......E1...
fd ff ff 55 48 89 e5 41-57 41 56 41 55 41 54 53 ...UH..AWAVAUATS
50 b8 58 52 00 00 e8 48-ba 05 00 48 29 c4 58 4c P.XR...H...H).XL
Binary Images:
0x10e472000 - 0x10e4b9fff mds_stores (*) <22bb7556-29af-3c8f-8726-b6f5dbbb3ba1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
0x7ff81a044000 - 0x7ff81a07eff7 libsystem_kernel.dylib (*) <3690c1fc-599f-39ff-bbdb-85422e9a996c> /usr/lib/system/libsystem_kernel.dylib
0x7ff81a0e4000 - 0x7ff81a57dffc com.apple.CoreFoundation (6.9) <9daa29f3-fe48-39a9-a70d-1e0fd4750372> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff819cf6000 - 0x7ff819d922ff dyld (*) <1289b60a-4980-342d-b1a4-250bbee392f1> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x7ff81a07f000 - 0x7ff81a08afff libsystem_pthread.dylib (*) <33c43114-85f0-3f32-86d7-8e6a2403d38c> /usr/lib/system/libsystem_pthread.dylib
0x7ff833c60000 - 0x7ff834020ffb com.apple.spotlight.index (1.0) <83c18296-a91e-3061-b8b9-7728a28b7099> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7ff819eda000 - 0x7ff819f20ffd libdispatch.dylib (*) <5203f33a-d525-32a5-bd79-2cce93555aee> /usr/lib/system/libdispatch.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=571.8M resident=0K(0%) swapped_out_or_unallocated=571.8M(100%)
Writable regions: Total=1.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.4G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 1
Dispatch continuations 192.0M 2
Kernel Alloc Once 8K 1
MALLOC 1.1G 160
MALLOC guard page 144K 36
Mach message 48K 2
Memory Tag 240 20K 5
Memory Tag 241 720K 5
Memory Tag 243 36.0M 6
Memory Tag 244 24.1M 42
Memory Tag 246 (reserved) 14.0M 7 reserved VM address space (unallocated)
Memory Tag 250 1024K 1
STACK GUARD 56.2M 44
Stack 29.8M 44
VM_ALLOCATE 340K 8
__CTF 824 1
__DATA 21.0M 413
__DATA_CONST 25.2M 267
__DATA_DIRTY 1280K 143
__FONT_DATA 2352 1
__LINKEDIT 179.7M 3
__OBJC_RO 70.6M 1
__OBJC_RW 2154K 2
__TEXT 392.1M 435
dyld private memory 260K 2
mapped file 641.8M 285
shared memory 40K 4
TOTAL 2.7G 1921
TOTAL, minus reserved VM space 2.7G 1921
Full Report
{"app_name":"mds_stores","timestamp":"2023-10-24 07:56:12.00 -0400","app_version":"","slice_uuid":"22bb7556-29af-3c8f-8726-b6f5dbbb3ba1","build_version":"","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309","os_version":"macOS 14.0 (23A344)","roots_installed":0,"incident_id":"183AB2C9-1FC5-4C72-9372-DE7E874656D5","name":"mds_stores"}
"uptime" : 42000,
"procRole" : "Default",
"version" : 2,
"userID" : 0,
"deployVersion" : 210,
"modelCode" : "MacPro7,1",
"coalitionID" : 265,
"osVersion" : {
"train" : "macOS 14.0",
"build" : "23A344",
"releaseType" : "User"
"captureTime" : "2023-10-24 07:56:04.6840 -0400",
"codeSigningMonitor" : 0,
"incident" : "183AB2C9-1FC5-4C72-9372-DE7E874656D5",
"pid" : 15882,
"cpuType" : "X86-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2023-10-24 07:56:01.9690 -0400",
"procStartAbsTime" : 42119898628916,
"procExitAbsTime" : 42122470000570,
"procName" : "mds_stores",
"procPath" : "\/System\/Library\/Frameworks\/CoreServices.framework\/Versions\/A\/Frameworks\/Metadata.framework\/Versions\/A\/Support\/mds_stores",
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.apple.Spotlight",
"crashReporterKey" : "49D02254-34C1-C565-E1BF-2D2ABB62978E",
"throttleTimeout" : 10,
"codeSigningID" : "com.apple.mds_stores",
"codeSigningTeamID" : "",
"codeSigningFlags" : 570522385,
"codeSigningValidationCategory" : 1,
"codeSigningTrustLevel" : 4294967295,
"sip" : "enabled",
"vmRegionInfo" : "0xbad is not in any region. Bytes before following region: 140737488278611\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n shared memory 7ffffffee000-7ffffffef000 [ 4K] r-x\/r-x SM=SHM ",
"exception" : {"codes":"0x0000000000000001, 0x0000000000000bad","rawCodes":[1,2989],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000bad"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":15882},
"vmregioninfo" : "0xbad is not in any region. Bytes before following region: 140737488278611\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n shared memory 7ffffffee000-7ffffffef000 [ 4K] r-x\/r-x SM=SHM ",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 21,
"threads" : [{"id":325094,"threadState":{"r13":{"value":21592279046},"rax":{"value":268451845},"rflags":{"value":518},"cpu":{"value":0},"r14":{"value":2},"rsi":{"value":21592279046},"r8":{"value":0},"cr2":{"value":4563419136},"rdx":{"value":8589934592},"r10":{"value":35197256990720},"r9":{"value":35197256990720},"r15":{"value":35197256990720},"rbx":{"value":140701814277712},"trap":{"value":133},"err":{"value":16777263},"r11":{"value":518},"rip":{"value":140703565109806},"rbp":{"value":140701814277552},"rsp":{"value":140701814277448},"r12":{"value":4294967295},"rcx":{"value":140701814277448},"flavor":"x86_THREAD_STATE","rdi":{"value":140701814277712}},"queue":"com.apple.main-thread","frames":[{"imageOffset":6702,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":1},{"imageOffset":65098,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":1},{"imageOffset":35694,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":1},{"imageOffset":7455,"symbol":"mach_msg","symbolLocation":19,"imageIndex":1},{"imageOffset":509045,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":2},{"imageOffset":503525,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":2},{"imageOffset":500594,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":2},{"imageOffset":24026,"imageIndex":0},{"imageOffset":25510,"symbol":"start","symbolLocation":1942,"imageIndex":3}]},{"id":325095,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":3843},"r8":{"value":409603},"cr2":{"value":4400836608},"rdx":{"value":123145448955904},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145449480192},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145449480192},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145449480192}}},{"id":325096,"threadState":{"r13":{"value":1103806595584},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":123145450016768},"rsi":{"value":1103806595584},"r8":{"value":0},"cr2":{"value":4511535424},"rdx":{"value":0},"r10":{"value":0},"r9":{"value":160},"r15":{"value":0},"rbx":{"value":22},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703565120982},"rbp":{"value":123145450012544},"rsp":{"value":123145450012392},"r12":{"value":900793000},"rcx":{"value":123145450012392},"flavor":"x86_THREAD_STATE","rdi":{"value":140560515145392}},"queue":"*\/Store","frames":[{"imageOffset":17878,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":1},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":5},{"imageOffset":970172,"symbol":"si_scheduler_suspend","symbolLocation":266,"imageIndex":6},{"imageOffset":1884463,"symbol":"si_verify","symbolLocation":145,"imageIndex":6},{"imageOffset":959926,"symbol":"compaction_runLoop","symbolLocation":110,"imageIndex":6},{"imageOffset":666478,"symbol":"work_fun","symbolLocation":859,"imageIndex":6},{"imageOffset":65538,"symbol":"_dispatch_block_async_invoke2","symbolLocation":85,"imageIndex":7},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":7},{"imageOffset":38504,"symbol":"_dispatch_lane_serial_drain","symbolLocation":816,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":44864,"symbol":"_dispatch_workloop_invoke","symbolLocation":803,"imageIndex":7},{"imageOffset":80622,"symbol":"_dispatch_root_queue_drain_deferred_wlh","symbolLocation":271,"imageIndex":7},{"imageOffset":78845,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":451,"imageIndex":7},{"imageOffset":11335,"symbol":"_pthread_wqthread","symbolLocation":327,"imageIndex":5},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":5}]},{"id":325097,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":14083},"r8":{"value":409603},"cr2":{"value":140559943512064},"rdx":{"value":123145450029056},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145450553344},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145450553344},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145450553344}}},{"id":325098,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":13827},"r8":{"value":409603},"cr2":{"value":123145469847640},"rdx":{"value":123145450565632},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145451089920},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145451089920},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145451089920}}},{"id":325099,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":21507},"r8":{"value":409604},"cr2":{"value":4638900232},"rdx":{"value":123145451102208},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145451626496},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145451626496},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145451626496}}},{"id":325100,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":20995},"r8":{"value":409604},"cr2":{"value":140559767352328},"rdx":{"value":123145451638784},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145452163072},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145452163072},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145452163072}}},{"id":325101,"frames":[{"imageOffset":6702,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":1},{"imageOffset":65098,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":1},{"imageOffset":35694,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":1},{"imageOffset":7455,"symbol":"mach_msg","symbolLocation":19,"imageIndex":1},{"imageOffset":6534,"symbol":"_handleExceptions","symbolLocation":120,"imageIndex":6},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":5},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}],"threadState":{"r13":{"value":17179869186},"rax":{"value":268451845},"rflags":{"value":514},"cpu":{"value":0},"r14":{"value":4096},"rsi":{"value":17179869186},"r8":{"value":0},"cr2":{"value":4546134016},"rdx":{"value":0},"r10":{"value":94570884890624},"r9":{"value":94570884890624},"r15":{"value":94570884890624},"rbx":{"value":123145452695440},"trap":{"value":133},"err":{"value":16777263},"r11":{"value":514},"rip":{"value":140703565109806},"rbp":{"value":123145452690976},"rsp":{"value":123145452690872},"r12":{"value":1},"rcx":{"value":123145452690872},"flavor":"x86_THREAD_STATE","rdi":{"value":123145452695440}}},{"id":325102,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":23299},"r8":{"value":409604},"cr2":{"value":5538930688},"rdx":{"value":123145452711936},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145453236224},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145453236224},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145453236224}}},{"id":325103,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":31491},"r8":{"value":409603},"cr2":{"value":140560087351296},"rdx":{"value":123145453248512},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145453772800},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145453772800},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145453772800}}},{"id":325104,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":23555},"r8":{"value":409603},"cr2":{"value":4866584582},"rdx":{"value":123145453785088},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145454309376},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145454309376},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145454309376}}},{"id":325105,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":23811},"r8":{"value":409604},"cr2":{"value":140559973924896},"rdx":{"value":123145454321664},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":123145454844792},"rbx":{"value":123145454845952},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145454845952},"r12":{"value":5193731},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145454845952}}},{"id":325106,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":31235},"r8":{"value":409604},"cr2":{"value":5530861568},"rdx":{"value":123145455394816},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145455919104},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145455919104},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145455919104}}},{"id":325107,"threadState":{"r13":{"value":140560517061792},"rax":{"value":0},"rflags":{"value":518},"cpu":{"value":0},"r14":{"value":70},"rsi":{"value":2310470504},"r8":{"value":9792476981821838646},"cr2":{"value":4701195164},"rdx":{"value":0},"r10":{"value":0},"r9":{"value":7097058},"r15":{"value":0},"rbx":{"value":70},"trap":{"value":133},"err":{"value":33554527},"r11":{"value":518},"rip":{"value":140703565121578},"rbp":{"value":123145455370224},"rsp":{"value":123145455369096},"r12":{"value":0},"rcx":{"value":123145455369096},"flavor":"x86_THREAD_STATE","rdi":{"value":70}},"queue":"*\/Store","frames":[{"imageOffset":18474,"symbol":"fsync","symbolLocation":10,"imageIndex":1},{"imageOffset":2940621,"symbol":"prot_fsync","symbolLocation":201,"imageIndex":6},{"imageOffset":814903,"symbol":"fd_sync","symbolLocation":292,"imageIndex":6},{"imageOffset":920677,"symbol":"indexPerformSync","symbolLocation":149,"imageIndex":6},{"imageOffset":919646,"symbol":"indexPerformSyncBulk","symbolLocation":429,"imageIndex":6},{"imageOffset":282699,"symbol":"_CISyncContextSync","symbolLocation":1389,"imageIndex":6},{"imageOffset":904865,"symbol":"_ContentIndexSyncIndexBulk","symbolLocation":319,"imageIndex":6},{"imageOffset":899583,"symbol":"syncIndex","symbolLocation":2896,"imageIndex":6},{"imageOffset":820904,"symbol":"flush_runLoop","symbolLocation":110,"imageIndex":6},{"imageOffset":666478,"symbol":"work_fun","symbolLocation":859,"imageIndex":6},{"imageOffset":65538,"symbol":"_dispatch_block_async_invoke2","symbolLocation":85,"imageIndex":7},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":7},{"imageOffset":38504,"symbol":"_dispatch_lane_serial_drain","symbolLocation":816,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":24374,"symbol":"_dispatch_continuation_pop","symbolLocation":122,"imageIndex":7},{"imageOffset":22332,"symbol":"_dispatch_async_redirect_invoke","symbolLocation":710,"imageIndex":7},{"imageOffset":75638,"symbol":"_dispatch_root_queue_drain","symbolLocation":328,"imageIndex":7},{"imageOffset":77602,"symbol":"_dispatch_worker_thread2","symbolLocation":152,"imageIndex":7},{"imageOffset":11270,"symbol":"_pthread_wqthread","symbolLocation":262,"imageIndex":5},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":5}]},{"id":325108,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":24067},"r8":{"value":409604},"cr2":{"value":140560593448960},"rdx":{"value":123145455931392},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":123145456454520},"rbx":{"value":123145456455680},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145456455680},"r12":{"value":5193733},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145456455680}}},{"id":325109,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":43275},"r8":{"value":409603},"cr2":{"value":140559775772672},"rdx":{"value":123145457541120},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145458065408},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145458065408},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145458065408}}},{"id":325110,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":33283},"r8":{"value":409604},"cr2":{"value":140560593444864},"rdx":{"value":123145458077696},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145458601984},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145458601984},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145458601984}}},{"id":325111,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":42755},"r8":{"value":409603},"cr2":{"value":4542332928},"rdx":{"value":123145457004544},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145457528832},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145457528832},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145457528832}}},{"id":325112,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":27919},"r8":{"value":409604},"cr2":{"value":123145464971264},"rdx":{"value":123145458614272},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145459138560},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145459138560},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145459138560}}},{"id":325113,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":33539},"r8":{"value":409604},"cr2":{"value":4400836608},"rdx":{"value":123145459150848},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145459675136},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145459675136},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145459675136}}},{"id":325114,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":43011},"r8":{"value":409603},"cr2":{"value":140704658056608},"rdx":{"value":123145456467968},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145456992256},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145456992256},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145456992256}}},{"triggered":true,"id":325115,"instructionState":{"instructionStream":{"bytes":[80,44,0,72,141,13,169,135,44,0,186,243,2,0,0,235,50,49,255,232,116,166,23,0,72,137,195,72,133,192,76,141,5,206,224,43,0,76,15,69,192,72,141,61,169,160,45,0,72,141,53,116,80,44,0,72,141,13,65,81,44,0,186,231,2,0,0,49,192,232,13,167,23,0,72,137,223,232,247,226,42,0,191,255,255,255,255,232,217,170,30,0,132,192,116,16,199,4,37,173,11,0,0,239,190,173,222,232,93,224,42,0,199,4,37,0,12,0,0,239,190,173,222,232,77,224,42,0,72,137,223,68,137,238,232,95,115,0,0,132,192,116,12,76,139,115,16,76,137,225,233,222,253,255,255,69,49,246,233,237,253,255,255,85,72,137,229,65,87,65,86,65,85,65,84,83,80,184,88,82,0,0,232,72,186,5,0,72,41,196,88,76],"offset":96}},"threadState":{"r13":{"value":123145460181104},"rax":{"value":1},"rflags":{"value":66050},"cpu":{"value":8},"r14":{"value":26624},"rsi":{"value":123145460178520},"r8":{"value":0},"cr2":{"value":2989},"rdx":{"value":0},"r10":{"value":123145460211884},"r9":{"value":50000},"r15":{"value":5},"rbx":{"value":140560516121488},"trap":{"value":14,"description":"(no mapping for user data write)"},"err":{"value":6},"r11":{"value":514},"rip":{"value":140703998070125,"matchesCrashFrame":1},"rbp":{"value":123145460180768},"rsp":{"value":123145460180720},"r12":{"value":123145460181084},"rcx":{"value":18268060175662973166},"flavor":"x86_THREAD_STATE","rdi":{"value":140704001060417}},"queue":"*\/0","frames":[{"imageOffset":839021,"symbol":"storageAllocOffset","symbolLocation":766,"imageIndex":6},{"imageOffset":867685,"symbol":"storageGrowOffset","symbolLocation":287,"imageIndex":6},{"imageOffset":866614,"symbol":"reallocBlock","symbolLocation":646,"imageIndex":6},{"imageOffset":841291,"symbol":"mergeEntryFlat","symbolLocation":2203,"imageIndex":6},{"imageOffset":837477,"symbol":"mergeEntryFat","symbolLocation":1301,"imageIndex":6},{"imageOffset":835850,"symbol":"bt_mergeEntry","symbolLocation":138,"imageIndex":6},{"imageOffset":394270,"symbol":"bt_mergeCallback","symbolLocation":238,"imageIndex":6},{"imageOffset":829489,"symbol":"index_FlushCache","symbolLocation":5857,"imageIndex":6},{"imageOffset":909744,"symbol":"indexPrepareForSyncBulk","symbolLocation":809,"imageIndex":6},{"imageOffset":281832,"symbol":"_CISyncContextSync","symbolLocation":522,"imageIndex":6},{"imageOffset":904865,"symbol":"_ContentIndexSyncIndexBulk","symbolLocation":319,"imageIndex":6},{"imageOffset":899583,"symbol":"syncIndex","symbolLocation":2896,"imageIndex":6},{"imageOffset":820904,"symbol":"flush_runLoop","symbolLocation":110,"imageIndex":6},{"imageOffset":666478,"symbol":"work_fun","symbolLocation":859,"imageIndex":6},{"imageOffset":65538,"symbol":"_dispatch_block_async_invoke2","symbolLocation":85,"imageIndex":7},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":7},{"imageOffset":38504,"symbol":"_dispatch_lane_serial_drain","symbolLocation":816,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":44864,"symbol":"_dispatch_workloop_invoke","symbolLocation":803,"imageIndex":7},{"imageOffset":80622,"symbol":"_dispatch_root_queue_drain_deferred_wlh","symbolLocation":271,"imageIndex":7},{"imageOffset":78845,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":451,"imageIndex":7},{"imageOffset":11335,"symbol":"_pthread_wqthread","symbolLocation":327,"imageIndex":5},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":5}]},{"id":325116,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":42499},"r8":{"value":409604},"cr2":{"value":140559973924896},"rdx":{"value":123145460224000},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":123145460747128},"rbx":{"value":123145460748288},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145460748288},"r12":{"value":5193733},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145460748288}}},{"id":325117,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":34051},"r8":{"value":409604},"cr2":{"value":140560081588224},"rdx":{"value":123145460760576},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145461284864},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145461284864},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145461284864}}},{"id":325118,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":42243},"r8":{"value":409603},"cr2":{"value":140559973924896},"rdx":{"value":123145461297152},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":123145461820280},"rbx":{"value":123145461821440},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145461821440},"r12":{"value":5193731},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145461821440}}},{"id":325119,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":40971},"r8":{"value":409604},"cr2":{"value":5543694336},"rdx":{"value":123145461833728},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145462358016},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145462358016},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145462358016}}},{"id":325131,"threadState":{"r13":{"value":17180131331},"rax":{"value":268451845},"rflags":{"value":518},"cpu":{"value":0},"r14":{"value":44},"rsi":{"value":17180131331},"r8":{"value":107382772346903},"cr2":{"value":4755013804},"rdx":{"value":549757064467},"r10":{"value":173752901976067},"r9":{"value":173752901959680},"r15":{"value":173752901959680},"rbx":{"value":123145462886936},"trap":{"value":133},"err":{"value":16777263},"r11":{"value":518},"rip":{"value":140703565109806},"rbp":{"value":123145462886576},"rsp":{"value":123145462886472},"r12":{"value":0},"rcx":{"value":123145462886472},"flavor":"x86_THREAD_STATE","rdi":{"value":123145462886936}},"queue":"*\/St","frames":[{"imageOffset":6702,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":1},{"imageOffset":65098,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":1},{"imageOffset":35694,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":1},{"imageOffset":7455,"symbol":"mach_msg","symbolLocation":19,"imageIndex":1},{"imageOffset":232982,"imageIndex":0},{"imageOffset":169906,"imageIndex":0},{"imageOffset":912396,"symbol":"sync_datastore","symbolLocation":269,"imageIndex":6},{"imageOffset":282246,"symbol":"_CISyncContextSync","symbolLocation":936,"imageIndex":6},{"imageOffset":904865,"symbol":"_ContentIndexSyncIndexBulk","symbolLocation":319,"imageIndex":6},{"imageOffset":899583,"symbol":"syncIndex","symbolLocation":2896,"imageIndex":6},{"imageOffset":820904,"symbol":"flush_runLoop","symbolLocation":110,"imageIndex":6},{"imageOffset":666478,"symbol":"work_fun","symbolLocation":859,"imageIndex":6},{"imageOffset":65538,"symbol":"_dispatch_block_async_invoke2","symbolLocation":85,"imageIndex":7},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":7},{"imageOffset":38504,"symbol":"_dispatch_lane_serial_drain","symbolLocation":816,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":7},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":7},{"imageOffset":24374,"symbol":"_dispatch_continuation_pop","symbolLocation":122,"imageIndex":7},{"imageOffset":22332,"symbol":"_dispatch_async_redirect_invoke","symbolLocation":710,"imageIndex":7},{"imageOffset":75638,"symbol":"_dispatch_root_queue_drain","symbolLocation":328,"imageIndex":7},{"imageOffset":77602,"symbol":"_dispatch_worker_thread2","symbolLocation":152,"imageIndex":7},{"imageOffset":11270,"symbol":"_pthread_wqthread","symbolLocation":262,"imageIndex":5},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":5}]},{"id":325132,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":35843},"r8":{"value":409604},"cr2":{"value":123145464979456},"rdx":{"value":123145462906880},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145463431168},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145463431168},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145463431168}}},{"id":325133,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":35587},"r8":{"value":409603},"cr2":{"value":4403339264},"rdx":{"value":123145463443456},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145463967744},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145463967744},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145463967744}}},{"id":325134,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":39939},"r8":{"value":409603},"cr2":{"value":5530857472},"rdx":{"value":123145463980032},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":123145464503160},"rbx":{"value":123145464504320},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145464504320},"r12":{"value":5193733},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145464504320}}},{"id":325135,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":38659},"r8":{"value":409604},"cr2":{"value":5538359296},"rdx":{"value":123145464516608},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145465040896},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145465040896},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145465040896}}},{"id":325136,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":37891},"r8":{"value":409603},"cr2":{"value":4402466816},"rdx":{"value":123145465053184},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145465577472},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145465577472},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145465577472}}},{"id":325137,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":37635},"r8":{"value":409603},"cr2":{"value":140559524069884},"rdx":{"value":123145465589760},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145466114048},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145466114048},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145466114048}}},{"id":325138,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":64787},"r8":{"value":409603},"cr2":{"value":123145470345216},"rdx":{"value":123145466126336},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145466650624},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145466650624},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145466650624}}},{"id":325147,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":63747},"r8":{"value":409604},"cr2":{"value":5543698432},"rdx":{"value":123145466662912},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145467187200},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145467187200},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145467187200}}},{"id":325148,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":46619},"r8":{"value":409603},"cr2":{"value":123145469808640},"rdx":{"value":123145467199488},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145467723776},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145467723776},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145467723776}}},{"id":325169,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":58627},"r8":{"value":409603},"cr2":{"value":140559775772672},"rdx":{"value":123145467736064},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145468260352},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145468260352},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145468260352}}},{"id":325170,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":48643},"r8":{"value":409603},"cr2":{"value":140560085778432},"rdx":{"value":123145468272640},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145468796928},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145468796928},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145468796928}}},{"id":325171,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":57863},"r8":{"value":409604},"cr2":{"value":123145470384216},"rdx":{"value":123145468809216},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145469333504},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145469333504},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145469333504}}},{"id":325172,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":47375},"r8":{"value":409604},"cr2":{"value":4857599344},"rdx":{"value":123145469345792},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145469870080},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145469870080},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145469870080}}},{"id":325187,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":59931},"r8":{"value":409603},"cr2":{"value":4638900232},"rdx":{"value":123145469882368},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145470406656},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145470406656},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145470406656}}},{"id":325188,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":49155},"r8":{"value":409604},"cr2":{"value":123145451028480},"rdx":{"value":123145470418944},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145470943232},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145470943232},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145470943232}}},{"id":325189,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":49667},"r8":{"value":409604},"cr2":{"value":140560593620992},"rdx":{"value":123145470955520},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145471479808},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145471479808},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145471479808}}},{"id":325190,"frames":[{"imageOffset":7048,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":0},"rsi":{"value":50179},"r8":{"value":409604},"cr2":{"value":4511535424},"rdx":{"value":123145471492096},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":0},"rbx":{"value":123145472016384},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703565351816},"rbp":{"value":0},"rsp":{"value":123145472016384},"r12":{"value":0},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145472016384}}}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 4534509568,
"size" : 294912,
"uuid" : "22bb7556-29af-3c8f-8726-b6f5dbbb3ba1",
"path" : "\/System\/Library\/Frameworks\/CoreServices.framework\/Versions\/A\/Frameworks\/Metadata.framework\/Versions\/A\/Support\/mds_stores",
"name" : "mds_stores"
"source" : "P",
"arch" : "x86_64",
"base" : 140703565103104,
"size" : 241656,
"uuid" : "3690c1fc-599f-39ff-bbdb-85422e9a996c",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64h",
"base" : 140703565758464,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 4825085,
"uuid" : "9daa29f3-fe48-39a9-a70d-1e0fd4750372",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "2048.1.403"
"source" : "P",
"arch" : "x86_64",
"base" : 140703561637888,
"size" : 639744,
"uuid" : "1289b60a-4980-342d-b1a4-250bbee392f1",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 140703565344768,
"size" : 49152,
"uuid" : "33c43114-85f0-3f32-86d7-8e6a2403d38c",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703997231104,
"CFBundleShortVersionString" : "1.0",
"CFBundleIdentifier" : "com.apple.spotlight.index",
"size" : 3936252,
"uuid" : "83c18296-a91e-3061-b8b9-7728a28b7099",
"path" : "\/System\/Library\/PrivateFrameworks\/SpotlightIndex.framework\/Versions\/A\/SpotlightIndex",
"name" : "SpotlightIndex",
"CFBundleVersion" : "2268.10"
"source" : "P",
"arch" : "x86_64",
"base" : 140703563620352,
"size" : 290814,
"uuid" : "5203f33a-d525-32a5-bd79-2cce93555aee",
"path" : "\/usr\/lib\/system\/libdispatch.dylib",
"name" : "libdispatch.dylib"
"sharedCache" : {
"base" : 140703560941568,
"size" : 25769803776,
"uuid" : "62bff6a2-85e3-3e99-aa9c-94b8c34708c1"
"vmSummary" : "ReadOnly portion of Libraries: Total=571.8M resident=0K(0%) swapped_out_or_unallocated=571.8M(100%)\nWritable regions: Total=1.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.4G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nActivity Tracing 256K 1 \nDispatch continuations 192.0M 2 \nKernel Alloc Once 8K 1 \nMALLOC 1.1G 160 \nMALLOC guard page 144K 36 \nMach message 48K 2 \nMemory Tag 240 20K 5 \nMemory Tag 241 720K 5 \nMemory Tag 243 36.0M 6 \nMemory Tag 244 24.1M 42 \nMemory Tag 246 (reserved) 14.0M 7 reserved VM address space (unallocated)\nMemory Tag 250 1024K 1 \nSTACK GUARD 56.2M 44 \nStack 29.8M 44 \nVM_ALLOCATE 340K 8 \n__CTF 824 1 \n__DATA 21.0M 413 \n__DATA_CONST 25.2M 267 \n__DATA_DIRTY 1280K 143 \n__FONT_DATA 2352 1 \n__LINKEDIT 179.7M 3 \n__OBJC_RO 70.6M 1 \n__OBJC_RW 2154K 2 \n__TEXT 392.1M 435 \ndyld private memory 260K 2 \nmapped file 641.8M 285 \nshared memory 40K 4 \n=========== ======= ======= \nTOTAL 2.7G 1921 \nTOTAL, minus reserved VM space 2.7G 1921 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "*\/0"
"logWritingSignature" : "438ec97e1c3a66d953a3cd5c4db27d6399faff89"
Never tried it until Sonoma XD was trying to get performance back. was hoping the XcpmForceBoost was the cause of the "unresponsive CPU bitmap" crashes
Attach your EFI to ensure everything is added as expected and when you have green signals, perform a clean install and we'll see how it goes.
delta385852
