Tracking down random Kernel Panics after Sonoma Install . Any help would be greatly appreciated .
So, now, after swapping Vega 64 for 6800XT
I can remove PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)
from the device properties altogether ?
just delete the whole DP from the PCILIST ?
Before I assume, I want to be clear and specific.
Yes, of course. It was neither required for VEGA 64 as well ;)
It's always good to ask!
Thanks EM86 for taking the time to reply.
Anytime!
Added Whatevergreen.kext
Added BootArg (gdpmod=pikera -wegnoigpu)
Removed PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0) from the device properties. and Reset NvRAM.
Now at startup, the progress bar loads about 25% screen goes black and fans on GPU stop.
I can still log-in on the black screen, so know the system is booted to the desktop.
But the display never comes on.
Ah, you're using wrong boot args. It's not gdpmod=piera. But agdpmod=pikera.
Reactions: SpoolingTurbo6
Ah, you're using wrong boot args. It's not gdpmod=pikera. But agdpmod=pikera.
Good Eye. wonder how many times I've looked at that and didn't even see it .!?
Will run this EFI and see if crashes persists .
Will run this EFI and see if crashes protist
So, what's the report?
It feels sluggish . and not as snappy as before... but running steady .
Geekbench score is 1,500-2,000 lower. and Cinebench is 3,000 points lower.
No crashes yet, but it was taking a day or two on the regular . especially if I walked away and came back to use the machine .. about 5 min after the, the keyboard would start acting funny .
Still getting Kernel Panic under normal usage.
IPI timeout, unresponsive CPU bitmap
Process name corresponding to current thread (0xffffff8be3160b50): coreaudiod
mp_kdp_enter() timed-out on cpu 6, NMI-ing
mp_kdp_enter() NMI pending on cpus: 0 2 3
mp_kdp_enter() timed-out during locked wait after NMI;expected 24 acks but received 22 after 10801333 loops in 1593600000 ticks
panic(cpu 6 caller 0xffffff8003561922): IPI timeout, unresponsive CPU bitmap: 0x4, NMIPI acks: 0x0, now: 0x0, deadline: 27841487164872, pre-NMIPI time: 0x195259f3d685, current: 0x195277c13cb7, global: 1 @pmap.c:3092
Panicked task 0xffffff90b2454428: 9 threads: pid 236: coreaudiod
Backtrace (CPU 6), panicked thread: 0xffffff8be3160b50, Frame : Return Address
0xfffffff83046b470 : 0xffffff800343a111 mach_kernel : _handle_debugger_trap + 0x4b1
0xfffffff83046b4c0 : 0xffffff8003597be0 mach_kernel : _kdp_i386_trap + 0x110
0xfffffff83046b500 : 0xffffff800358732c mach_kernel : _kernel_trap + 0x55c
0xfffffff83046b580 : 0xffffff80033d6951 mach_kernel : _return_from_trap + 0xc1
0xfffffff83046b5a0 : 0xffffff800343a3fd mach_kernel : _DebuggerTrapWithState + 0x5d
0xfffffff83046b690 : 0xffffff8003439aa3 mach_kernel : _panic_trap_to_debugger + 0x1e3
0xfffffff83046b6f0 : 0xffffff8003bd900b mach_kernel : _panic + 0x84
0xfffffff83046b7e0 : 0xffffff8003561922 mach_kernel : _pmap_flush_tlbs + 0x852
0xfffffff83046b8b0 : 0xffffff80035682dd mach_kernel : _pmap_remove_range + 0x25d
0xfffffff83046b980 : 0xffffff8003568ef1 mach_kernel : _pmap_remove_options + 0x231
0xfffffff83046b9d0 : 0xffffff80034ef9b2 mach_kernel : _vm_map_destroy + 0x1192
0xfffffff83046bb50 : 0xffffff80034e94ad mach_kernel : _kmem_alloc_pageable + 0xe7d
0xfffffff83046bba0 : 0xffffff8003a8c3e9 mach_kernel : __ZN11OSSerialize4freeEv + 0x59
0xfffffff83046bbd0 : 0xffffff8003b4c5d7 mach_kernel : _is_io_registry_entry_get_property_bin_buf + 0x4e7
0xfffffff83046bc40 : 0xffffff8003544add mach_kernel : _iokit_server_routine + 0x57cd
0xfffffff83046bca0 : 0xffffff8003412d90 mach_kernel : _ipc_kmsg_send + 0x570
0xfffffff83046bd60 : 0xffffff800342ab68 mach_kernel : _mach_msg_overwrite_trap + 0x5d8
0xfffffff83046bdd0 : 0xffffff800342b1d8 mach_kernel : _mach_msg2_trap + 0x3b8
0xfffffff83046bef0 : 0xffffff800356c8d2 mach_kernel : _mach_call_munger64 + 0x1f2
0xfffffff83046bfa0 : 0xffffff80033d6db6 mach_kernel : _hndl_mach_scall64 + 0x16
Boot args: keepsyms=1 debug=0x100 agdpmod=pikera -wegnoigpu
Mac OS version:
23A344
Kernel version:
Darwin Kernel Version 23.0.0: Fri Sep 15 14:42:42 PDT 2023; root:xnu-10002.1.13~1/RELEASE_X86_64
Kernel UUID: 0905511D-D697-32D8-8069-EA653FED4635
roots installed: 0
KernelCache slide: 0x0000000003000000
KernelCache base:  0xffffff8003200000
Kernel slide:      0x00000000030e0000
Kernel text base:  0xffffff80032e0000
__HIB  text base: 0xffffff8003100000
System model name: MacPro7,1 (Mac-27AD2F918AE68F61)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 27842987669737
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x00001952b363bc28
  Sleep   : 0x0000000000000000 0x0000000000000000 0x0000000000000000
  Wake    : 0x0000000000000000 0x00000013df3be08e 0x0000000000000000
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
  Zone map: 0xffffff80ad3cf000 - 0xffffffa0ad3cf000
  . PGZ   : 0xffffff80ad3cf000 - 0xffffff80b53d0000
  . VM    : 0xffffff80b53d0000 - 0xffffff8580d69000
  . RO    : 0xffffff8580d69000 - 0xffffff871a09c000
  . GEN0  : 0xffffff871a09c000 - 0xffffff8be5a35000
  . GEN1  : 0xffffff8be5a35000 - 0xffffff90b13ce000
  . GEN2  : 0xffffff90b13ce000 - 0xffffff957cd67000
  . GEN3  : 0xffffff957cd67000 - 0xffffff9a48701000
  . DATA  : 0xffffff9a48701000 - 0xffffffa0ad3cf000
  Metadata: 0xffffffc0efdfc000 - 0xffffffc10fdfc000
  Bitmaps : 0xffffffc10fdfc000 - 0xffffffc11bdfc000
  Extra   : 0 - 0
Provide a Video and include the IOReg and System Report.
kcbednar
