- Aug 10, 2023
- MSI B350M Pro VDH
- 2200G
- Vega 8
- OpenCore (Legacy)
I installed Mac Ventura successfully on my system, but when I insert the kext nootedred It started to give issues! Someone help me!
I added plist and log here.
00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:026 00:026 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:052 00:026 AAPL: #[EB|H:IS] 0
00:078 00:026 AAPL: #[EB|LOG:INIT] 2023-09-13T08:33:42
00:104 00:026 AAPL: #[EB|VERSION] <"boot.efi 577.140.215 (Official), built 2023-06-23T21:49:39-0700">
00:130 00:026 AAPL: #[EB|BUILD] <"BUILD-INFO[402]:{"DisplayName":"boot.efi","DisplayVersion":"577.140.215","RecordUuid":"15CF17D7-4948-416B-9222-69F5AA379466","BuildTime":"2023-06-23T21:49:39-0700","ProjectName":"efiboot","ProductName":"boot.efi","SourceVersion":"577.140.2","BuildVersion":"15","BuildConfiguration":"Release","BuildType":"Official","Compiler":"clang-1403.0.22.11","SdkVersion":"13.5","SdkBuild":"22G62","TargetArchitectures":"x86_64"}">
00:156 00:026 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:183 00:026 AAPL: #[EB|CFG
EV] r5 0x0 0x0
00:209 00:026 AAPL: #[EB|GFWF!] Err(0xE) <- 5
00:235 00:026 AAPL: #[EB|GFWF!] Err(0xE) <- 33
00:261 00:026 AAPL: #[EB|GFWF!] Err(0xE) <- 23
00:930 00:668 AAPL: #[EB|H:IS] 0
00:956 00:026 AAPL: #[EB|WL:MODE] 0
00:982 00:026 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
01:008 00:026 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
01:049 00:041 AAPL: #[EB|CFG:ARG] console 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
01:075 00:026 AAPL: #[EB|CFG:ARG] serial 0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
01:101 00:026 AAPL: #[EB|CFG:ARG] preoslog 0x0000000000000001 (0x0000000000000001 < 0xFFFFFFFFFFFFFFFF) default
01:127 00:025 AAPL: #[EB|CFG:ARG] timestamps 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
01:153 00:026 AAPL: #[EB|CFG:ARG] log-level 0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
01:179 00:026 AAPL: #[EB|CFG:ARG] breakpoint 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
01:206 00:026 AAPL: #[EB|CFG:ARG] kc-read-size 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
01:232 00:026 AAPL: #[EB|CFG:ARG] force-error 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
01:258 00:026 AAPL: #[EB|H:IS] 0
01:284 00:026 AAPL: #[EB|WL] 0 0 0x01 0x01 0 0x00
01:310 00:026 AAPL: #[EB|BRD:SMBIOS] Mac-27AD2F918AE68F61
01:336 00:026 AAPL: #[EB|B:VAw]
01:362 00:026 AAPL: #[EB|B:IAw]
01:389 00:026 AAPL: #[EB|WL] 0 0 0x01 0x01 2 0x00
01:415 00:026 AAPL: #[EB|B:RRVAR]
01:442 00:026 AAPL: #[EB|B:MLBVAR] Düÿÿ4üÿÿ(üÿÿ�üÿÿ
01:468 00:025 AAPL: #[EB.BST.IDT|+]
01:495 00:027 AAPL: #[EB.BST.IDT|-]
01:521 00:025 AAPL: #[EB|WL] 0 0 0x01 0x01 3 0x00
01:562 00:041 AAPL: #[EB|WL] 0 0 0x01 0x01 4 0x00
01:588 00:025 AAPL: #[EB|BRD:SMBIOS] Mac-27AD2F918AE68F61
01:614 00:026 AAPL: #[EB|WL] 0 0 0x01 0x01 5 0x00
02:293 00:678 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
02:319 00:025 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:345 00:026 AAPL: #[EB|WL] 0 0 0x01 0x01 23 0x0E
02:371 00:025 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:397 00:025 AAPL: #[EB|WL] 0 0 0x01 0x01 24 0x0E
02:423 00:026 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:449 00:026 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:475 00:026 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:501 00:025 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:527 00:025 AAPL: #[EB|H:NOT]
02:553 00:026 AAPL: #[EB|SB
] 0x1
02:579 00:026 AAPL: #[EB.B.MN|BM:+SB]
02:612 00:032 AAPL: #[EB|LIMG
P] Acpi(PNP0A03,0)/Pci(1|2)/Pci(0|1)/SATA(5,FFFF)/HD(Part2,Sig92F01006-20F3-4673-A2CD-63C67CDD2229)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842)
02:638 00:025 AAPL: #[EB|LIMG:FP] \6BFF979B-9030-450B-9BA2-FE09E40184B4\System\Library\CoreServices\boot.efi
02:664 00:026 AAPL: #[EB|LIMG:OPT]
02:690 00:026 AAPL: #[EB.OPT.LXF|F] <"\6BFF979B-9030-450B-9BA2-FE09E40184B4\System\Library\CoreServices\com.apple.Boot.plist">
02:716 00:025 AAPL: #[EB.LD.LF|IN] 0 1 <"\6BFF979B-9030-450B-9BA2-FE09E40184B4\System\Library\CoreServices\com.apple.Boot.plist"> <"0">
02:757 00:041 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\6BFF979B-9030-450B-9BA2-FE09E40184B4\System\Library\CoreServices\com.apple.Boot.plist">
02:783 00:026 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
02:809 00:026 AAPL: #[EB.OPT.LXF|F] <"Library\Preferences\SystemConfiguration\com.apple.Boot.plist">
02:836 00:026 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\Preferences\SystemConfiguration\com.apple.Boot.plist"> <"0">
02:863 00:027 AAPL: #[EB|KF] <"">
02:889 00:026 AAPL: #[EB|MBA:CL] <"">
02:915 00:026 AAPL: #[EB|MBA:NV] <"slide=184">
02:941 00:026 AAPL: #[EB|MBA:KF] <"">
03:620 00:678 AAPL: #[EB|MBA:OUT] <"slide=184">
03:646 00:026 AAPL: #[EB.CSR.S|VAR] 0x00000040
03:672 00:025 AAPL: #[EB|OPT:BM] 0x280100
03:698 00:026 AAPL: #[EB.OPT.LXF|F] <"\6BFF979B-9030-450B-9BA2-FE09E40184B4\System\Library\CoreServices\PlatformSupport.plist">
03:724 00:026 AAPL: #[EB.LD.LF|IN] 0 1 <"\6BFF979B-9030-450B-9BA2-FE09E40184B4\System\Library\CoreServices\PlatformSupport.plist"> <"0">
03:751 00:026 AAPL: #[EB|P:CPR] N
03:777 00:025 AAPL: #[EB|P:MPI] N
03:803 00:026 AAPL: #[EB|P:BPI] N
03:829 00:025 AAPL: #[EB.OPT.RKS|!] Err(0xE) <- BS.LocP EDB4A040-6D8A-11EC-8FAD-3E22FB93ADCF
03:855 00:025 AAPL: #[EB|KMR] 319700992
03:880 00:025 AAPL: #[EB.CS.CSKSD|+]
03:922 00:041 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
03:948 00:025 AAPL: #[EB|WL] 0 0 0x01 0x01 6 0x0E
03:974 00:025 AAPL: #[EB.CS.LFC|+]
04:000 00:026 AAPL: #[EB.LD.LF|IN] 0 1 <"System\Library\Caches\com.apple.corestorage\EncryptedRoot.plist.wipekey"> <"0">
04:059 00:059 AAPL: #[EB.FS.AGSVH|PU] 6BFF979B-9030-450B-9BA2-FE09E40184B4
04:085 00:025 AAPL: #[EB.FS.AGSVH|!] Err(0xE) <- BS.LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
04:111 00:026 AAPL: #[EB.G.CS|-?] Ok(0)
04:169 00:057 AAPL: #[EB.LD.LF|IN] 0 1 <""> <"1">
04:197 00:028 AAPL: #[EB.B.SBS|SZ] 723512
04:229 00:032 AAPL: #[EB|B:SHA]
04:255 00:025 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
04:281 00:026 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
04:308 00:026 AAPL: #[EB.WL.PWLFRTC|NONE]
04:334 00:025 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
04:360 00:026 AAPL: #[EB.LD.LKC|D] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.development">
04:386 00:026 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.development"> <"0">
04:412 00:026 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.development">
04:438 00:026 AAPL: #[EB.LD.LKC|R.2] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc">
04:464 00:026 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\System\Library\KernelCollections\BootKernelExtensions.kc"> <"0">
06:717 02:252 AAPL: #[EB|SB
] 0x1
06:771 00:053 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m
06:797 00:026 AAPL: #[EB|SB:MF] boot\System\Library\KernelCollections\BootKernelExtensions.kc.x86legacyap.im4m
06:823 00:026 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.x86legacyap.im4m"> <"0">
07:146 00:322 AAPL: #[EB.SB.VK|!] Err(0x1A) <- 24B73556-2197-4702-82A8-3E1337DAFBF2.VFB MKRN
07:175 00:028 AAPL: #[EB.SB.VK|!] Err(0x1A) <- 24B73556-2197-4702-82A8-3E1337DAFBF2.VFB MKRD
07:201 00:026 AAPL: #[EB.LD.LKCFFP|!] Err(0x1A) <- EB.SB.SBVK
07:233 00:031 AAPL: #[EB|R:SRBM] secure-boot
07:266 00:032 AAPL: #[EB|IRM:RMD]
07:301 00:034 AAPL: #[EB|R:ARB]
07:327 00:026 AAPL: #[EB|WL] 0 0 0x01 0x41 6 0x0E
07:353 00:026 AAPL: #[EB|RESET] 1
07:379 00:025 AAPL: #[EB|LOG:RESET:RECOVERY] 2023-09-13T08:33:50
