Ventura installed on Z690M-PLUS D4 is stuck at start::512:Successfully initialized AHCI controller
helenpayne261
10.13.x
  1. Other
hardware information:
Computer Model ASUS Desktop PC
Processor 12th Gen Intel Core i7-12700KF Octa-Core
Motherboard ASUS PRIME Z690M-PLUS D4 (LPC Controller/eSPI Controller Z690 chipset)
Graphics AMD Radeon RX 5700 XT ( 8 GB / Dylan )
Memory 32 GB ( Kingston DDR4 3600MHz 32GB )
Primary Hard Drive Western Digital WD Blue SN570 1TB SSD (1 TB / Solid State Drive)
Sound Card Realtek @ Intel High Definition Audio Controller
Network card Intel Ethernet Connection I219-V / ASUS
OC:OpenCore9.4
Installation image: macOS+Ventura+13.3.1 (22E261)
USB:2.0
Fault:is stuck at start::512:Successfully initialized AHCI controller
Kexts:
ACPL:
Can someone help me?
OC:OpenCore9.4
USB:2.0
Kexts:
ACPL:
Prepare the EFI in accordance with the guide linked below
I'm having the same issue like you:
My specs:
  • HP Prodesk 600 G3
  • i5 6500
  • RX 560 4GB
  • 8GB DDR4 RAM
Here's my EFI
My specs:
  • HP Prodesk 600 G3
  • i5 6500
  • RX 560 4GB
  • 8GB DDR4 RAM
Here's my EFI
On a side note, do NOT hijack another user's thread. Always create your own separate thread to track the progress of the issues at one page.
Also, check your Inbox.
natsukiro
