SOLVED Sleep/Wake USB problems. Acer Aspire 5
Hi ElitMacx86.
In the first place I appologise for my rude answer.
No worries. Apologies accepted!
I searched a lot for info before my post seeking help.
I thought that ProperTree put the kexts in the right order, by saying kexts I mean drivers. I changed the order in OpenCore Configurator but if you say that they are in incorrect order maybe its because I use ProperTree to refresh my settings.
Dont get me wrong please, but I was despered seeking help, I´m sorry.
I thank You sincerelly.
I understand
I have NVMeFix because I have a NVMe drive for Windows dualboot. Should I remove it anyway?
Yes, of course. It's no longer being maintained.
I´m going to make all the changes you said.
Sounds good!
I again.
After your settings advice I cant boot to MacOS anymore, in UEFI settings the boot option disppeared, only can boot to MacOS from usb without your advice settings...
Thank You.
Attach your EFI to check further!
Hi.
Sorry for the late answer.
I´m on holidays with wife and kids, and only by night I can be here.
I´ll attached the EFI folder.
I added the -v options in bootargs and took a picture so you can see where it stops.
Once again I thank You for you help.
  • EFI.zip
    EFI.zip
Hi.
Try to Enable "EnablWriteUnprotector" and Disable "RebuildAppleMemoryMap" Quirk in Booter section.
Hi.
Just tested with those settings.
Now it boots, but after sleep I still get the usb disconnected.
Thank You once more.
Hugo.
Hi.
Hugo.
Apply PRW patch to prevent the instant wake.
Just made it!! Wow!! I can say that the problem is solved! It goes to sleep, no more instant Wake, I wake it with mouse or keyboard, and all my usb devices remain conected!!
Thank You so much!!!
Just one more question.
My monitor is detected as unknown. Is that important or I have to change anything more? Or I can leave it this way?
Thank you big time EliteMacx86!!
Great!
It's absolutely normal!
You're welcome. Closing this thread now.
Reactions: hugocarmo
xmax114
