Help Installing Hackintosh on My System
dogusyolal
ASRock B760M PG Sonic WiFi DDR5
Intel Core i5-13400F
Asrock RX 6900 XT Phantom Gaming D
İ5 13400f
Asrock B760M PG SONIC WiFi DDR5
Asrock phantom gaming rx 6900 xt
CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL36
LC-POWER LC1000M 1000W
Thermalright Frozen Notte 240 WHITE
Kingston 1TB Fury Renegade SFYRS/1000G
Nzxt H5 Flow RGB
This is my system parts and I want to install mac os. Can you help me how to do it and how to edit the efi file suitable for my motherboard? I have not installed it on a desktop computer before. Will I have parts that are not working? I could not find many efi folders installed with b760 and 6900xt on the internet. Thank you everyone in advance.
İ5 13400f
Nzxt H5 Flow RGB
Your hardware is supported.
Thank you, I will try and let you know.
I created an efi by examining the guide you gave, but I could not get past the error in the picture. There are no forums that I haven't reviewed, can you help me?
Efi
Efi
Here are a few issues:
- Remove Device Properties for IGPU. IGPU is not supported since Intel Rocket Lake.
- Kexts loading order is not correct. Important Kexts should load first. In addition, you should only load mandatory kexts during install. Moreover, the BT kexts are not appropriate. If you have Intel WiFi/BT, see the guide here.
- Add Cpuid1Data (55060A00 00000000 00000000 00000000) and Cpuid1Mask (FFFFFFFF 00000000 00000000 00000000) in Kernel>Emulate section. Alder Lake and newer require CPU spoofing in order to boot.
- Incorrect SMBIOS. The ideal SMBIOS for your hardware is iMacPro1,1. iMac requires a IGPU, which is not in your case due to the reason not being supported under macOS.
- Remove HfsPlus.efi and use OpenHfsPlus.efi. You should not load duplicate drivers.
Once you're done with the changes, save your config.plist. Restart the system and reset NVRAM twice. The installer should boot now. If not, attach the new PR files.
I did what you said but I keep getting the same error. I am using the same files from the bluetooth location you provided. I don't have a mac computer I'm trying to do as much as I can through windows.
Efi
Efi
You have clearly not followed the guide.
IntelBluetoothInjector.kext is should not be used on macOS Monterey and newer.
Irrelevant kexts are still present. Kexts are still not in proper order.
It was mentioned to use HfsPlus.efi. You avoided that and used OpenHFSPlus.efi.
Also, enable SetupVirtualMap quirk in Booter section.
In addition, make sure your BIOS Settings are appropriate.
I recreated it. But this time an error like oc failed occurred.
Efi2
g.gott81
