SOLVED Intel Bluetooth not working on Ventura
Pranay
Hp Elitebook 840 G3 motherboard
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
Intel HD Graphics 520
  2. Clover (Legacy)
  3. OpenCore (UEFI)
  4. OpenCore (Legacy)
  2. iMac Pro
  3. Mac Pro
  4. Mac mini
  5. MacBook
  6. MacBook Air
  7. MacBook Pro
  3. Windows Phone
  4. Other
Hey Team,
I was using macOS monterey and I recently updated to macOS Ventura using igpu patch (My graphics do not support natively)but after booting my bluetooth is not working so I tried replacing the bluetooth kext for the lates one available but still its not working. I will attach my EFI. Need anything else please ask.
ThankYou
For SKL, there is already a solution.
What WiFi/BT model your Laptop has?
Yeah I had already did that its already working.
Intel WiFi and Bluetooth card [WiFi is Intel(R) Dual Band Wireless AC-8260]
Nice!
Add the following keys in the NVRAM>7C436110-AB2A-4BBB-A880-FE41995C9F82 section of your config.plist
bluetoothInternalControllerInfo:00000000 00000000 00000000 0000
bluetoothExternalDongleFailed:00
Set the Type to DATA.
Once you're done with the changes, save your config.plist.
Restart the system and reset NVRAM twice. Check the Bluetooth function. If it does not work, attach the new PR files.
It worked when I restarted but then when I tried turning it OFF and ON, once I turn it OFF its not turning on back ON.
PR FILES
PR FILES
It's a bug. Test the attached kexts and then report.
alvarg82
