Intel uhd 630: i5 10400 4mb vram (comet-lake)
Nostalgation
i5 10400 intel
intel uhd 630 and rtx 3060
10.13.x
Hi, I need help with my intel uhd 630 running macos big sur:
OS: Macos big sur olarila .raw image
CPU: intel i5 10400
IGPU: intel uhd 630 (comet-lake GT-2)
RAM: 16 gb
Screen Resolution: 1366 x 768
cable for screen: VGA to HDMI adapter
Bootloader: Opencore 9.1
any fix for this issue ??
Note: i tried this fix https://elitemacx86.com/threads/how...cs-comet-lake-on-macos-big-sur-and-later.897/ (didn't work)
I tried following a lot of youtube videos and none of them worked
I also tried following some threads on this forum and i followed the fixes on the opencore manual and the whatevergree manual too
but still no luck
CPU: intel i5 10400
RAM: 16 gb
but still no luck
No PR Files attached.
I don't actually know the exact files but here's my whole efi folder if you want to check it out. with this efi folder it boots without graphics acceleartion. this is what i'm using rn
Note: i still haven't removed the efi folder from the usb so whenever i bwant to boot i have to plug the usb in for now (untill i have a fix for the graphics)
A lot of issues in your configuration.
However, as this thread is limited to Graphics only, the reason why the acceleration is not working is that you're using AAPL,slot-name instead of AAPL,ig-platform-id. Both things are different.
i don't actually know the diffrence between them tho i've tried a lot of "fixes" and none of them worked. what should i change for it to work properly and is there any recommends to help improve my experience on macos bigsur ?
Note: just to make it alot easier to actually understand my situation i'm trying to run macos bigsur on an Optilex 3080 Dell you can look the i5 10400 model up if you need the motherboard model
It really does not matter much what you have tried and is no surprise if they didn't work. Sometimes, the effort is made in the wrong direction which brings 0 results.
Read post #4
In case, if you still don't have clue, change AAPL,slot-name to AAPL,ig-platform-id in the Device Properties section of your config.plist.
Read post #4
That didn't work sadly
are you sure nothing else is missing ? like a kext or an argument ?
Note: I'm using a vga to hdmi adapter anything have to do with that ?
have you success i have same issue like you..
xmax114
