high sierra error impossible contact the server
Select CT480... and click on Erase button.
Use the following parameters to erase.
Format: APFS
Scheme: GUID Partition Map
Click on Erase. Then proceed to install.
Not work
Sorry now im not at home i had to go..but in 2 hours i will send you..but I did the erase like you say..
Okay, sure. No rush. Take your time!
Thanks..Anyway i did what you say
Format: APFS
Format: APFS
After that, did you click on Erase to continue erasing the drive?
Yes and I see te green check too
And then, did you select Macintosh HD to continue with the installation?
I cant get to this screen where i select the drive..i have only the first continue and the error
ryusuke17
