Dell G3 15 3500: unable to get trackpad and HDMI working
hoaug
Dell 0Y5DDC
i5-4590T
HD4600
10.13.x
Hi everybody
I'm a newbie who successfully installed macOS this morning. pretty luckily everything works fine except the trackpad. I cannot turn it on. I've spent this whole day learning Patch and trying to fix the trackpad but with no success. I really need your help
My Dell G3 15 3500 laptop configuration:
  • CPU: Intel i7-10750h
  • iGPU: Intel UHD630
  • dGPU: Nvidia GTX 1650ti (Disabled with SSDT)
  • RAM: 16GB
  • SSD: SK Hynix BC511 512GB
  • Sound: ALC295
  • LAN: Killer E2500
  • WIFI: Intel (I forgot but it works fine)
  • Trackpad: DELL09E1, I2C1.TPDA, I2CHID
i tried many kext, i used kext VoodooI2C+VoodooI2CHID but it doesn't work ( i tried alpsHID.kext but also not working ) . My battery is working fine. I tried to patch SSDT for trackpad but it seems I did something wrong
. same thing happens with HDMI. Someone please help me, thank you very much..
below is my EFI, ioreg and DSDT copy:
Hi everybody
  • RAM: 16GB
  • Sound: ALC295
  • LAN: Killer E2500
The HDMI might be connected to the NVIDIA/AMD GPU. So, check in Windows first.
Regarding the Trackpad, your patching isn't correct.
Thanks for answering!. I tried to fix the trackpad but it didn't work. The HDMI I checked in the Nvidia Control Panel under Physx and found that I can choose to output from the Card or the CPU. Does this make any sense?. Is there any guide for patching SSDT trackpad?. HDMI I tried Patch Connector and Patch BusID but all failed, please help me...
Here's a guide
Very soon, there will be a guide for I2C.
delta385852
