SOLVED OPENCORE REBOOTING AFTER SELECTING INSTALLER
The output looks clean.
However, it is not working because you've injected kext directly into OC, which cannot always be used as it is not always possible to inject using userspace.
Remove IONetworkingFamily.kext completely from Kernel>Add section in your config.plist and also from the EFI/OC/Kexts directory.
Once you're done with the changes, save your config.plist and make sure to empty the bin. Restart the system and reset NVRAM twice. Attach the new PR files.
Aight I did what you said, and here are the PR Files.
Nope Its not working. Should I add IONetworkingFamily.kext and force it?
Why do you even need to use that? It's already present in S/L/E. If you deleted it, you must restore it in order to make your WiFi working.
If nothing works, try itlwm+Heliport
I took one of the pre-build EFI from Olarila.com and customised somethings according to my laptop/OS and every thing is working all good. So I might use that.
ThankYou for your help :)
Olarila EFI
Olarila EFI
It's always advised to make your own EFI.
Closing this thread.
chirag11122
