- Mar 15, 2019
- dell 5559
- i5 6200u
- 520hd
- 11.0.x
- Clover (UEFI)
- Other
Specs of the laptop
You'll need a 16+ GB USB, a Mac and an internet connection to download the Installer. I won't be describing it way too much here though: for example, when I say "split your USB drive into two partitions", I assume you know how to use three double u dot google dot com
. So:
Customising The Installer
Lilu-- KERNEL PATCHES
SMC-- To spoof your cpu to make the pc believe this is an actual Mac an pull ionetworkingfamily.kext and others.
To Use FakeSMC download the latest zip and unzip all(not needed but its okay) .kext files to Clover/kexts/other
2) VirtualSMC-- A new version of SMC Emulator
make sure that the SMChelper.efi is not in EFI/Clover/drivers64UEFI. if there delete it.
Download the VirtualSMC release and copy VirtualSMC.efi from /Drivers to EFI/Clover/drivers64UEFI
copy the kexts from /Kexts to EFI/CLOVER/Kexts/Other
**//YOU CAN ONLY USE ONE//**
VOODOOPS/2- TO Make the Mouse/Touchpad, keyboard work.
AppleALC- To enable audio (fixing audio guide down)
Realtek Ethernet Driver - A custom version reddit user artikushg found which works nice.
OSX-ACPI-Battery-Driver-- ONLY use with FAKESMC not VirtualSMC. battery driver.
VOODOOTSCSync- CPUCores better sync mostly.
APTIOFIXEFIDRIVERS-- Fixing various problems like Icloud Appstore. these are uefi drivers meant to be moved to /Clover/drivers64UEFI.
APFS DRIVERS-- APFS EFI DRIVERS meant to be moved to /Clover/drivers64UEFI
USE HFS+ IF YOU LIKE. FIND THE EFI DRIVERS ON WEB.
WhateverGreen = Fixing GPUs
NOW YOU NEED A CONFIG.PLIST FILE TO BOOT which would be located as /CLOVER/config.plist. YOU CAN BOOT WITH A VANILLA PLIST FILE or USE This as your base.
system bios info be like
secure boot = disabled (if you're a pro you know how to fix these later and FileVault Stuff)
vt-d = disabled
make a uefi boot entry as the file /Clover/CLOVERX64.EFI
NOW REBOOT AND install.
fixing audio
use Xcode or CloverConfigurator
add a boot arg as alcid=13
under Devices/Audio
Inject=3
resethda = true/tick
testing fix for amd gpu
AS IVE FOUND YET THE GPU IS OF GCN 1.0 ARCH. AND SHOULD WORK UNDER THE AMD800CONTROLLER.KEXT.
SO WE WILL INJECT A FAKEID AS A AMD8000 SUPPORTED BONNAIRE CHIP.
FAKEID = 0X1002665C
FBNAME = RADEON (OR ANY IT WILL GET THE BEST FRAMEBUFFER)
LOADVBIOS = TRUE
RADEONDEINIT = TRUE
INJECT AMD = TRUE
GRAPHICS IS DETECTING AS IRIS 550 WHILE DPCI AND SYSTEM REPORT SHOWS ITS SUPPORTED.
App Store AND ICLOUD FIX
APTIO DRIVER FIXES THE MAIN ISSUES BUT DO GENERATE A SMBIOS AS MAC BOOK PRO 13,1
sometimes not booting or booting issues.
use args
-v = verbose output on screen to debug
-f = to boot without caches.
- Intel Core i5-6200U (Working Nicely 52*C- 60*C on C6 state)
- Intel HD 520 (Working)
- AMD R5 M335 (Testing/ Partial Success)
- 8 GB RAM (2x 1600mhz Detecting Dual Channel)
- 1 TB SATA HDD (Working)
- HDMI (Working)
- DVD (Working)
- Realtek ALC3234 audio (working)
- Intel 3160 WiFi card (Not Supported)
- Realtek 8109 fast Ethernet (working)
- Web Camera (would be working as I have issues with using a laptop webcam)
- 2 USB 2.0 ports, 1 USB 3.0 port (all of them working)
- SD Card reader (trying to rebuild kext with a generic usb 2.0 crw kext)
- Open the AppStore, search for "macOS Mojave", download the app
- While it's downloading, use Disk Utility to split your USB into two partitions: one big, for the installer, formatted as Mac OS X Extended (Journaled), and one small, around 500 MB formatted as FAT32 (MS-DOS) for the EFI bootloader (CLOVER)
- Replace "INSERT_YOUR_USBS_NAME_HERE_FROM_DISK_UTILITY" with your USB drive's name
sudo /Applications/Install\ macOS\ Mojave.app/Contents/Resources/createinstallmedia --volume /Volumes/INSERT_YOUR_USB_NAME_FROM_DISK_UTILITY
- IT MAY ASK FOR YOUR ACC PASSWORD TO ACQUIRE ROOT PERMISSION, and it will take some time.
- FakeSMC -- The everywhere accepted and used SMC Spoof working and being maintained for years. this link is a RehabMan fork.
vt-d = disabled
fixing audio
under Devices/Audio
Inject=3
FAKEID = 0X1002665C
LOADVBIOS = TRUE
RADEONDEINIT = TRUE
INJECT AMD = TRUE
use args
