As mentioned, VMs are much more flexible. I may have 20 MacOS VMs sitting around and I can run any one of them easily, or create a temporary copy of one, use it and then delete the used one.
And too much lags and performance issues. Unless you use a passthrough.
Anyway, I found a solution here. Several of the built-in CPU types work, such as "Intel Core i7-6700K". Wasn't needed on the 8600K but apparently is on the 13900K.
Glad you found a solution.
