CPU Compatibility List For macOS [Intel/AMD]
As mentioned, VMs are much more flexible. I may have 20 MacOS VMs sitting around and I can run any one of them easily, or create a temporary copy of one, use it and then delete the used one.
And too much lags and performance issues. Unless you use a passthrough.
Anyway, I found a solution here. Several of the built-in CPU types work, such as "Intel Core i7-6700K". Wasn't needed on the 8600K but apparently is on the 13900K.
Glad you found a solution.
Can install Big Sur? My specs ryzen 5 5600, Memory 16 GB DDR4, 3060Ti 8GB
3060Ti isn't supported.
You'll need a compatible GPU.
Hello, Everyone, I hope you are doing well.
I planned to build a hackintosh in my motherboard strix b550 gaming with 2 PCI graphics slot. I will use one for rtx 2080 TI and the other RX 580 for perfect graphics support in ventura.
I really like the ryzen 9 5900X cpu but i wonder if it can run smoothly a hackintosh (Ventura).
So please here is my question. I want to know if RYZEN 9 5900X or RYZEN 7 5700X has smooth support in hackintosh.
Thank you
Thank you
Hello,
Both the CPUs are fully supported on Ventura and work like a charm if everything is configured correctly.
Hope this helps!
Sounds good. Thank you.
Please can i use your video guide for the process. This video is about Montrey. I do not know if it will work for ventura.
VIDEO LINK M
And also is OTA UPDATE supported ?
Thanks Again
VIDEO LINK M
Thanks Again
Yes, it's supported. Well, you can.
Great. The EFI video is missing on your channel. Can i use the EFI folder located here
https://github.com/acidanthera/OpenCorePkg/releases in X64 folder more precisely
Or do i need to create my EFI ?
Thank you
Thanks for the Guide and the support.
J.An
