- Mar 18, 2019
- Dell XPS-9350
- i7-6560U
- Intel HD540 (Iris)
- 10.14.x
- Clover (UEFI)
The configuration is upto the mark. I would need to check the BIOS setting you've configured and the Verbose log. Also, i suggest you to not use the AirportBrcmFixup before the installation. And still i doubt it's 1080p. I've already installed Mojave on the same laptop for a friend and it's QHD (3200x1800). Check the screen resolution in Windows and attach a screenshot from the drop down list.
Specs of my Model:
BIOS:
- Disabled Secure Boot
- Set SATA Operation to AHCI
- Disabled VT for Direct I/O (VT-d)
Just the Menu from my BIOS:
Windows:
Verbose-Log using the Folder above AND the AirportBrcmFixup.kext:
Verbose-Log WITHOUT AirportBrcmFixup (I needed to film it, and then take a Screenshot from the Error):
Thanks!
