DELL-XPS9350: Stuck at "IntelFBClientControl" and "AppleIntelFramebuffer"
The configuration is upto the mark. I would need to check the BIOS setting you've configured and the Verbose log. Also, i suggest you to not use the AirportBrcmFixup before the installation. And still i doubt it's 1080p. I've already installed Mojave on the same laptop for a friend and it's QHD (3200x1800). Check the screen resolution in Windows and attach a screenshot from the drop down list.
Specs of my Model:
BIOS:
  • Disabled Secure Boot
  • Set SATA Operation to AHCI
  • Disabled VT for Direct I/O (VT-d)
General Information (BIOS) (if you need anything specific, just hit me up! :giggle:):
Just the Menu from my BIOS:
Windows:
Verbose-Log using the Folder above AND the AirportBrcmFixup.kext:
Verbose-Log WITHOUT AirportBrcmFixup (I needed to film it, and then take a Screenshot from the Error):
Thanks! :)
Specs of my Model:
BIOS:
Windows:
Thanks! :)
Thank you for providing the information. But how without AirportBrcmFixup is resulting in the KP?
I guess my WifiCard is not supported, which results in the AirPortDriverBrcnNIC to crash.
Have you replaced the WiFi Card? Or it's the stock Intel one?
I've got the Solution! Thanks for the support from the inbox.
I've unscrewed the back, removed the WiFi-Card and booted just using the EFI-Folder above WITHOUT the AirportBrcmFixup.kext!
That's what was needed. Without the AirportBrcmFixup.kext.
Reactions: Headknockr
Legacy AMD Guy
