VMware for macOS
Again looking at the requirements to run macOS VMware, GPU is not one of them ever. Why is it important if i may ask....?
So what should i do now to solve this problem?
Either install a compatible GPU or upgrade the CPU in order to use the GPU. Also, rather than using VMware, install on bare metal.
For acceleration or it will be so much slower with artifacts. A detailed guide is coming very soon.
Thank you so much for your advice. I have lots of hard drives in my machine that enables me to install on the bare metal. Now we are back to my very first question. How do i get the macOS image file that will run on my machine successfully and how do i do it? Any help from you..?
Also with the specs of my machine previously mentioned can i install mac OS on the bare metal ?
Without a compatible GPU, there is no point in installing macOS. As stated previously, install a compatible GPU or upgrade the CPU in order to use the GPU.
You can install but still you need a compatible GPU for acceleration.
Thank you so much for your advice and i tell you i appreciate everything you have done to inform me. Looking at the specs i showed you earlier in our chat can you help me is a type of GPU card i should upgrade the machine with ....?
Again i i should upgrade the CPU which type should i use again looking at the specs of my machine ...?
That totally depends on your budget.
den.les
