How to Enable Intel HWP (Speed Shift Technology) on macOS
This guide covers the implementation of HWP (Speed Shift Technology) for Intel CPUs on macOS using Clover and OpenCore. By following this guide, you'll be able to enable HWP on your Intel CPU on macOS using Clover or OpenCore Bootloader.
What is Intel HWP (Speed Shift Technology)?
With the release of Skylake CPUs, Intel introduced a new Power Management Technology "Speed Shift Technology" (aka SST, aka HWP). Intel HWP (Hardware p-state) or Hardware Controlled Performance delivers quicker responsiveness with short duration performance shifts, by allowing the processor to more quickly select its best-operating frequency and voltage for optimal performance and power efficiency. In short, with SpeedShift enabled, the CPU handles the P-State Management by itself instead of requiring the OS to handle it. The CPU will automatically shift to higher and lower P-States depending on the workload.
Compatibility
As this is Intel's Proprietary Technology, only Intel CPUs are compatible. AMD CPUs use AMD SmartShift Technology, which is similar to Intel's Speed Shift Technology. HWP is supported on Intel® Broadwell and Skylake processors, though Intel® Speed Shift Technology is only supported by Skylake processors. For more information on CPU Compatibility, refer to the thread linked below.
In order to use HWP, there are certain requirements which have been described below
  • macOS Compatible Intel Skylake and newer CPU. See CPU Compatibility for more information.
SMBIOS
  • HWP supported SMBIOS. See HWP SMBIOS Compatibility Table
Patch
  • xcmp_idle patch
  • OS X 10.11 and Later
Currently, the following SMBIOS supports HWP.
LineupSMBIOS
MacBook
  • MacBook9,1, MacBook10,1
MacBookPro
  • MacBookPro13,x, MacBookPro14,x, MacBookPro15,x, MacBookPro16,x
MacBookAir
  • MacBookAir8,x, MacBookAir9,1
Mac mini
  • Macmini8,1
iMac
  • iMac17,1, iMac18,x, iMac19,x, iMac20,x
iMacPro
  • iMacPro1,1
MacPro
  • MacPro7,1
STEP 1: Enable CPU Power Management
The very first step is to enable CPU Power Management on your System. To enable CPU Power Management, follow the guide linked below.
STEP 2: Setup SMBIOS
The next step is to set up a correct System Definition (SMBIOS) according to your CPU model. To setup SMBIOS, follow the guide linked below
STEP 3: Restart your System
Verifying HWP
The next step is to verify whether HWP is enabled or not.
Download IOReg and open it.
1. Verify the plugin-type property. The plugin-type property is located under the CPU node.
2. Verify the loading of X86PlatformPlugin. The X86PlatformPlugin is located under the CPU node.
wojko
