You are mentiion often something about PR files..i dont understand what are these?
PR files means Problem Reporting Files. A list of required PR files is described in the first post of this guide.
No PR files attached.
Here is the question: I have deleted AppleALC and VooodooHDA, hoping to get it work with apples original driver, from the OC kexts folder.I've bought this liitle tool.
HTML:
https://www.savio.net.pl/en/product/savio-ak-01-usb-7-1-ch-sound-card/
which works perfect,once i turn on the computer.If i reboot it becomes crancking and rare have working sound.What can I do?Please help.
Here is my EFi without making an opencore Snapshot. I have already did with the installed one, But it does not work.I thing there must be wrong withthe config file
Thanks
HTML:
Thanks
On AMD, such issues are normal. Make sure your USB ports are mapped and the BIOS settings are correct.
How can i map the usb?
Could You please add the A++ series patch to config file for me?,My Coomputer has the A-10 CPUs series . I'm using the AMD FX patch for now
Do you know an online guide how to map the USB port?
Does this post works for amd CPUs?
hubalala
