GUIDE How to Create macOS Ventura Bootable USB
the first is that it has several .im4m files inside it, is that right?
With macOS Ventura, it's completely normal.
And the second when I went to mount the compatible EFI to put OpenCore in it, I saw that I can't record and "apple udfi read only memory" appears. What can it be
Indicates a USB issue.
Only happens with Ventura….
Format your USB again with the parameters as per the guide.
Download the desired macOS version and create the Bootable USB. If you see any error, attach screenshot.
Snowson
