Boot problem
juanjoryx
LENOVO IdeaPad 3 15ADA05
AMD Ryzen 3 3250U with Radeon Graphics
Radeon Graphics
12.x
Hi,
This is my first time trying to install hackintosh, I've been trying for 2 days but I don't get much, I've tried several tutorials to create the EFI, but only the one on this forum seems to work a little,
It seems that in my EFI everything is configured well, I don't know, please if someone can help me configure my EFI I would be grateful, for now everything I have achieved can be seen in the video that I attach, I also leave the EFI that I am using attached.
I think my laptop information is on my profile, but I'll leave it here again:
Laptop: Lenovo IdeaPad 3 15ADA05
CPU: AMD Ryzen 3 3250U
Hi,
Here are a few issues:
- Your system does not need SSDT-CPUR.aml
- Why are you using DevirtualiseMmio and EnableWriteUnprotector? Disable both and use RebuildAppleMemoryMap
- Why are you using NootedRed and WhateverGreen together? Only use NootedRed.kext.
- Assuming you're booting Ventura+ (13.3+), you must set the correct core count.
- Why are you using nvme=-1? Are you sure your internal NVMe drive isn't compatible with macOS?
- UnblockFsConnect is only required on HP Systems.
sabbianera
