Anyone try Final Cut Pro 11 Magnetic Mask? Getting glitches on 14700K system... Ideas?
bhuether
Asus Z790 ProArt Creator
i7 14700k
6950 XT Red Devil
Hi, I have
Asus Z790 Proart
14700K
6950 XT
Sonoma 14.7
iMacPro1,1 SMBIOS
OC 1.0
I am noticing glitches in magnetic mask. The analysis seems to go fine, but if I use the brush tools to modify the mask, each brush stroke gradually erodes the whole mask.
Also, after hitting Done to finish the mask and extract the subject, if I then place solid background below, say white, then I see that background come through the entire subject a little bit, as if the whole mask is partially transparent. That is, even though the mask looks black, it is partially transparent.
Here I show what I mean:
I don't see any info from Apple suggesting magnetic mask doesn't work with intel and on apple community site intel users say it works fine. But since I have hackintosh, maybe something is just not working. So trying to see what others are experiencing and if there are known workarounds.
My 6950 XT GPU works fine, it produces around 270000 in Geekbench metal. In FCP settings it shows GPU as "AMD Radeon HD GFX10 Family Unknown Prototype". No idea if that suggests anything. I have always seen that, and in Geekbench it also shows that as the GPU, but the GPU works fine in any apps that use GPU, renders in FCP are indeed using the GPU, hardware decoding works. So all seems fine.
Ideas?
thanks
Hi, I have
Asus Z790 Proart
14700K
6950 XT
Sonoma 14.7
iMacPro1,1 SMBIOS
OC 1.0
Ideas?
thanks
The link is broken!
Nope, that didn't work either. Maybe try as code:
https://imgur.com/a/fcp-11-magnetic-mask-glitches-CbkWv9b
No idea why link isn't working. Here it is without any auto embedding that might be messing it up:
Will try and see.
Yes, it seems like imgur Embedding isn't working. Thanks for pointing it out!
The Graphics Acceleration does not seem to work. The Dock doesn't seems to be transparent. Unless you have enabled reduced transparency. Your profile indicates that you have 6950XT which requires Device ID spoofing. Inject 73BF as Device ID and the issue should be fixed!
Before you try to change the Device ID, attach Hackintool PCIe tab info+System Report.
I probably have reduced transparency. I mean metal score is 270000. Or could there be other GPU related functionality not working? hardware decode/encode works. Render times in FCP are super fast and GPU usage goes up quite a bit.
I do indeed use GPU to 6900 spoof. 73BF is what mac sees on my system.
I suspected.
Could be possible. Cannot say without having a look at PR Files.
What are PR files?
What are PR files?
ploukop
