Dual boot windows (base) add MacOS-OC single drive
Maybe I wasn't clear on that note. So the wifi worked fine during the Recovery Install method. Once Catalina was installed, the wifi driver that was used during the recovery didn't load. I guess I need to now manually install the kext under MacOS Catalina? Do you have a doc on how to install wifi driver (the kext) once Catalina is running?
Well, that's weird. If you've still not corrected the config.plist, correct that in the first place.
lovos33
