How to enable HiPDi on Mohave with RDM custom resolution?
Nikos365
Levovo V-110
intel i3 60060U
intel Graphics 520
10.14.x
Hi
Whenever I try to create a new resolution scale on rdm I got this message? A little help would be appreciated on how to fix this issue.
thanks
Hi
thanks
Seems like you're trying to override.
Use the following command to enable HiDPI
bash -c "$(curl -fsSL https://raw.githubusercontent.com/xzhih/one-key-hidpi/master/hidpi.sh)"
I need some kind of command to override. The above method does not do anything. The boot screen apple is normal after reboot and Hidpi is not "enabled'
Plz Help!
Plz Help!
Enter the above command to enable HiDPI. Once enabled, you can use RDM to enable Custom Resolution. All previous work must be cleared.
I can do it with RDM, I jus need to override with the edit option, I tried a dozen time the above method. The cmd App does not do anything
check the screenshot
Anyways I have just installed Monterey, But it boots on Black Screen and Apple Icon is Huge. I can't provide PR files it does not boot at all. Any way on how to make it bootable again
Check my EFI
Please check this
nnaa
