SOLVED AMD A10 7850K reboots when setting up Mac
Nikos365
Levovo V-110
intel i3 60060U
intel Graphics 520
10.14.x
Hi
I'm trying to install and configure the MacOS Mojave after installation(config about Siri, keyboard language, etc.., but the system crashes it reboots),
I've got those error on start up :
Failed to add ACPI SSDT-EC-USBX-DESKTOP,
Inserted ACPI table has length mismatch 142565 vs 1007290890
The system reboots
Some help, Plz?
MySpecs :
AMD a-10 7850
Asrock A-68 Fm2Dg3+
16GB DDR3
ASUS Strix rx480 8GB
128GB SSD
Hi
The system reboots
Some help, Plz?
MySpecs :
AMD a-10 7850
Asrock A-68 Fm2Dg3+
16GB DDR3
128GB SSD
Is normal in Mojave. Follow UPDATE #2 as mentioned here.
"Reboot the macOS in single-user mode ( -s ) " is it a boot arg? or disk utility and mount the drive..etc?
Yes, correct. Using Boot Arg.
Is there any way around it without single user -s. When applying single user, the keyboard is not responding
None of the keys work? Try the Keyboard in a different port.
what about if open command line when i boot installer?
OK i followed the instructions on#UPDATE 2 the problem is not the privacy ..section is when choosing the keyboard type.. it reboots. Besides this command " dseditgroup -o edit -a temp -t user admin" is unknown to the system.
Any suggestions?
OK Succes but what is the username? It asks for username ? It has an icon 'says other..' and i click it asks for username and pass
The username is the one which you created. Follow the steps carefully.
scoobypetey
