I’m not using the AirportBrcmFixup kext because this is a native Apple card though
so, just to clarify, you want me to run that arg without the kext or with it?
The bootarg will not work without the AirPortBrcmFixup.
Yea, realized that
Well, I’ll try that kext once I get back home
Sorry for the delay, got busy with other stuff and kinda forgot about this lol
Loaded the kext and the boot arg, the issue is still there but seems to be worse (not pinging the router on 5GHz at all now)
And this is the only thing that changed
Also, ever since swapping to the Mac Pro SMBIOS, I stopped getting updated in the system settings app, need to download each update manually every time.
Any way to fix that without switching to a different SMBIOS?
Updated EFI folder
Connect to 5GHz. Press and hold Option Key on your Keyboard and click on WiFi. Provide a screenshot.
It doesn't want to connect to 5GHz networks anymore with this kext installed, even tried splitting my 2.4 and 5GHz networks into separate SSIDs
lupenyk
