sudo: ./tccplus: command not found
i think I'm doing something wrong, I got the master folder on the desktop, is this right?
The actual command would be
cd Desktop/Your folder name
can display this card and just work with another one Intel(R) Iris(R) Xe Graphics
Nope, no drivers were ever released for this.
Is there any way to make GTX1050 ti work with Ventura?
You can run High Sierra without any issues. However, there's experimental support for NVIDIA GPUs on macOS Big Sur and Monterey
What would be the best version of macOS I could run with this configuration?
MOTHERBOARD: B660 GAMING X DDR4
CPU: 12th Gen Intel(R) Core(TM) i9-12900F
GPU: NVIDIA GA104 [GeForce RTX 3070]
RAM: 32GB
Thanks.
RAM: 32GB
Thanks.
As per your hardware, none.
can it work for me im using monterey 12.6.5
its a good Pc
i forgot to add my hardware
MOTHERBOARD: Asus PRIME Z490-P
CPU: 10th Gen Intel(R) Core(TM) i7-10700F
GPU: RTX 3060 OC 12GB MSI
GPU: RTX 1650 MSI
RAM: 32GB
Can it work on the rtx or gtx is it possible
GPU: RTX 1650 MSI
RAM: 32GB
RTX isn't supported.
xmax114
