Hi, I have an i7 12700kf and an RTX 3070. If I want to put Hackintosh Monterey will it work?
  • Haha
Reactions: macpro
No RTX series GPUs are supported.
Hello, I have successfully enabled GTX 1060 on monetary 12.6.2 on my laptop
thank you so much for the help
only have one question can I enable SIP back after the patch?
I have a problem with giving my browser for example permission to access the microphone the applications are not showing in the security and privacy list in the microphone and camera section
That's nice.
Well, yes, once the system has been patched, you can re-enable the SIP or can completely disable it.
What version of OCLP have you used?
That's nice.
thanks for fast reply
the version i use 0.5.3
Due to the usage of amfi_get_out_of_my_way=1, macOS will fail to prompt users for special permissions upon application start as well as omit the entires in System Preferences. To work around this, we recommend users install tccplus to manage permissions.
thank you for the help, but how can I use it? I tried but it gave me this "
zsh: permission denied: ./tccplus"
Use sudo
sudo: ./tccplus: command not found
i think I'm doing something wrong, I got the master folder on the desktop, is this right?
xxxxxxxxxx
