Success. Thankyou! Followed Method #2 in your guide for making a standalone Ventura installer app using gibmacOS.
If you've got a minute to check my PR files, I'd appreciate your evaluation.
PR files: https://anonfiles.com/99b826E8y7/Archive_zip
Kextcache output problem: Executing sudo kextcache -i/ in Terminal yields error msg:
Unknown option '--check-rebuild'
(something about kextcache being deprecated and replaced by kmutil)
Here are a few issues.
- SSDT loading order is not correct. Important SSDTs should load first.
- Remove unused SSDT from ACPI directory and also from ACPI>Add section.
- Remove entry from ACPI>Patch section.
- IRQ Conflicts are not patched.
- Brightness not implemented. SSDT-PNLF is missing.
- Battery meter not implemented. ACPI is not patched.
- Remove the Devices except PciRoot(0x0)/Pci(0x1f,0x3) PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0) and PciRoot(0x0)/Pci(0x2,0x0).
- hda-gfx must be set to onboard-1 as STRING type.
- Connectors are not patched.
- Set KernelArch to Auto.
- As dGPU isn't supported in Optimus configuration, remove RadeonSensor and SMCRadeonGPU.kext.
- Remove RestrictEvents.kext
- AirportItlwm is more preferred over itlwm.
- Remove all the entries from Kernel>Patch section.
- Enable CustomSMBIOSGuid Quirk from Kernel>Quirks section.
- Remove all the tools entries from Misc>Tools section except for the one which you require.
- Set SecureBootModel to Default.
- Set Expose Sensitive Data to 6 Misc>Security.
- Remove agdpmod=pikera boot arg from NVRAM.
- Set the SMBIOS to MacBookPro15,2.
- Set UpdateSMBIOSMode to Custom.
- Remove the unused drivers.
Reactions: dman
Thankyou so much for this. Most generous 🙏🏾 It may take a few days to work through the list, am getting started and will report back asap.
Update: many of your suggested changes (eg RadeonSensor, SMCRadeonGPU.kext, RestrictEvents.kext, agdpmod=pikera, itlwm) are not present in my config.plist/EFI.
I downloaded my PR files from Post #60 and they are correct – the attachment link is https://anonfiles.com/99b826E8y7/Archive_zip
Could you please recheck?
Also, should I open a new topic for this discussion to keep the current thread clean?
Thanks
Surely. Take your time!
Great!
Have you implemented all the above changes?
Each new thread for a separate issue. Or a single dedicated thread for your Laptop.
Reactions: dman
Step #6 will format the target disk. Proceed with caution.
Thanks for the guide!
If I partition my ssd, will the part with windows be okay or will the whole drive be formatted?
If using GPT and the system is using UEFI Boot mode, you can Dual Boot both OS on a single drive. However, backup your ESP content first.
Reactions: Red
Preparing OpenCore EFI
Hey again! So after downloading the OS and preparing the USB I downloaded OpenCore but my 12th gen Intel Alder Lake isn’t an option.
I also realised after looking into OpenCore that no NVIDIA RTX cards (20 or 30 series) are compatible. I’ve got a 3080.
So I’ve got an unlisted cpu and an incompatible graphics card. I was hoping to use this for video editing and Xcode so not sure how the editing will go without a graphics card.
Is there any chance this would work? Not sure if I should go on from here. Have you got any experience with this? Thanks
Alder Lake is supported.
Yes, exactly. None of the NVIDIA RTX GPUs are compatible on any macOS version.
Well, IGPU is unsupported since Rocket Lake and NVIDIA aren't supported. The only option is upgrading to an AMD GPU.
In terms of GPU, no, not at all.
Experience with?
Thank you for your replies! I might go with AMD in the future then.
Experience with?
Would it still be usable without a GPU… or an IGPU I gues?
seph3421
