Stuck on launchd verbose screen, shuts down 15 minutes later
orpheus0001
Lenovo ThinkPad L450
Intel Core i3-5005U
Intel HD Graphics 5500
Monterey works just fine. Disabled itlwm and intelbluetooth kexts. MacBookPro14,1 and graphics id spoof as per the "How to Enable Intel HD Graphics (Haswell, Broadwell and Skylake) on macOS Ventura" guide.
No PR files attached.
You can use Google Drive, WeTransfer, OneDrive, DropBox, etc. The above link downloads an .HTML file.
My current config works just fine on Monterey, and I fail to see what I haven't done in your guide. Also, the section that has the links to all the configs for each cpu is broken. I just want to see why this behavior is happening so I can find out what to do about it. I can only assume it's something with CPU spoofing.
Edit: I've used the installer to install Ventura to a separate partition inside of Monterey. This picture shows where I think things go wrong. Seems to call a reboot here.
Sometimes, when things are messed up, it is better to start from scratch!
CPU Spoofing isn't required on Broadwell and neither it is present in your config.plist.
You should consider decluttering your configuration first, before you investigate the issues.
lovos33
