Latest update broke VT hardware encoder for OBS
VGNmac
M1 Air
  1. MacBook Air
Anyone have a fix for this? Crashes OBS after a few minutes of streaming. Worked flawless before the update.
Can you provide the exact Build Number?
It’s the latest beta. I believe public beta 5
Rollback or wait for an update. Also, how did you confirm if VT is broken?
obs crashes after a few minutes of streaming. is it possible to rollback to a previous beta?
Only if you have a Time Machine backup. Otherwise, you'll need to perform a clean install.
Also, make sure OBS is up to date.
so everthing would have to be wiped.. Cant do that. hopefully update fixes it
Hopefully. Keeping this thread opened until then.
@VGNmac
What's the SIP status?
xxxxxxxxxx
