GPU Panic
Muzam
MacBookPro11,3
Intel Iris Pro, NVIDIA GeForce GT 750M
10.14.x
Can someone please tell me the fix for kernal panic issue, It is gpu switching issue that appears sometimes when I boot up or run software that uses extra graphics processor. It got stucks and screen flicekers. Here is etre check report.
EtreCheck Report
EtreCheckPro version: 6.7.1 (67011)
Report generated: 2022-09-10 13:21:55
Download EtreCheckPro from https://etrecheck.com
Runtime: 3:12
Performance: Excellent
Problem:
No problem - just checking
Major Issues:
Anything that appears on this list needs immediate attention.
Automatic updates disabled - Automatic updates are disabled. This computer is at risk of malware infection.
Security updates disabled - Security updates are disabled. This computer is at risk of malware infection.
Kernel panics - This system has experienced kernel panics. This could be a sign of hardware failure.
Apple security disabled - Apple security software is disabled. This computer is at risk of malware infection.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
No Time Machine backup - Time Machine backup not found.
Apps crashing - There have been numerous app crashes.
Unsigned files - There are unsigned software files installed. These files could be old, incompatible, and cause problems. They should be reviewed.
Vintage hardware - This computer may be considered vintage.
x86-only Apps - This computer has x86-only apps might not work on future versions of the operating system.
Limited permissions - More information may be available with Full Disk Access.
Hardware Information:
MacBook Pro (Retina, 15-inch, Mid 2014)
Status: Vintage
MacBook Pro Model: MacBookPro11,3
2.5 GHz Quad-Core Intel Core i7 (i7-4870HQ) CPU: 4-core
16 GB RAM - Not upgradeable
BANK 0/DIMM0 - 8 GB DDR3 1600
BANK 1/DIMM0 - 8 GB DDR3 1600
Battery: Health = Normal - Cycle count = 265
Video Information:
Intel Iris Pro - VRAM: 1536 MB
Color LCD (built-in) 2880 x 1800
NVIDIA GeForce GT 750M - VRAM: 2 GB
Drives:
disk0 - APPLE SSD SM1024F 1.00 TB (Solid State - TRIM: Yes)
Internal PCI 5.0 GT/s x4 Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [APFS Container] 250.04 GB
disk3 [APFS Virtual drive] 250.04 GB (Shared by 7 volumes)
disk3s1 - F*********e (APFS) (15.32 GB used)
disk3s2 - Preboot (APFS) [APFS Preboot] (285 MB used)
disk3s3 - Recovery (APFS) [Recovery] (623 MB used)
disk3s4 - VM (APFS) [APFS VM] (1.07 GB used)
disk3s5 - M************* - Data (APFS) [APFS Virtual drive] (55.47 GB used)
disk3s6 - Update (APFS) (7 MB used)
disk3s7 (APFS) [APFS Container] (15.32 GB used)
disk3s7s1 - M***********e (APFS) [APFS Snapshot] (15.32 GB used)
disk0s3 [APFS Container] 375.15 GB
disk1 [APFS Virtual drive] 375.15 GB (Shared by 1 volumes)
disk1s1 - P********1 (APFS) (18.99 GB used)
disk0s4 [APFS Container] 375.15 GB
disk2 [APFS Virtual drive] 375.15 GB (Shared by 1 volumes)
disk2s1 - P*********2 (APFS) (729 KB used)
Mounted Volumes:
Filesystem: APFS
Mount point: /Volumes/P********1
Used: 18.99 GB
Shared values
Free: 356.02 GB
Filesystem: APFS
Mount point: /Volumes/P*********2
Used: 729 KB
Shared values
Free: 375.00 GB
Available: 375.01 GB
Filesystem: APFS
Mount point: /Volumes/F*********e
Read-only: Yes
Used: 15.32 GB
Shared values
Free: 161.80 GB
disk3s2 - Preboot [APFS Preboot]
Filesystem: APFS
Mount point: /System/Volumes/Preboot
Used: 285 MB
Shared values
Free: 161.80 GB
disk3s4 - VM [APFS VM]
Filesystem: APFS
Mount point: /System/Volumes/VM
Used: 1.07 GB
Shared values
Free: 161.80 GB
disk3s5 - M************* - Data [APFS Virtual drive]
Filesystem: APFS
Mount point: /System/Volumes/Data
Encrypted
Used: 55.47 GB
Shared values
Free: 161.80 GB
Available: 162.81 GB
disk3s6 - Update
Filesystem: APFS
Mount point: /System/Volumes/Update
Used: 7 MB
Shared values
Free: 161.80 GB
disk3s7 [APFS Container]
Filesystem: APFS
Mount point: /Volumes/M*************1
Encrypted
Used: 15.32 GB
Shared values
Free: 161.80 GB
disk3s7s1 - M***********e [APFS Snapshot]
Filesystem: APFS
Mount point: /
Read-only: Yes
Used: 15.32 GB
Shared values
Free: 161.80 GB
disk4s2 - E**********************]
Filesystem: Mac OS Extended
Disk Image
Mount point: /Volumes/E**********************]
Owners enabled: No
Read-only: Yes
Used: 30 MB
Free: 14 MB
Network:
Interface en0: Wi-Fi
802.11 a/b/g/n/ac
Interface en3: Bluetooth PAN
Interface bridge0: Thunderbolt Bridge
iCloud Quota: 5.00 GB available
System Software:
macOS Big Sur 11.6.8 (20G730)
Time since boot: Less than an hour
Security:
Gatekeeper: App Store and identified developers
System Integrity Protection: Enabled
Automatic Updates: Disabled
Security Updates: Disabled
Antivirus software: None!
Unsigned Files:
Apps: 2
Old Applications:
3 x86-only apps
System Launch Daemons:
[Not Loaded] 36 Apple tasks
[Loaded] 185 Apple tasks
[Running] 142 Apple tasks
[Other] One Apple task
System Launch Agents:
[Not Loaded] 16 Apple tasks
[Loaded] 180 Apple tasks
[Running] 138 Apple tasks
Launch Daemons:
[Loaded] com.adobe.acc.installer.v2.plist (Adobe Inc. - installed 2022-09-08)
[Running] com.adobe.agsservice.plist (Adobe Inc. - installed 2022-09-04)
Launch Agents:
[Running] com.adobe.AdobeCreativeCloud.plist (Adobe Inc. - installed 2022-09-03)
[Running] com.adobe.GC.AGM.plist (Adobe Inc. - installed 2022-09-04)
[Not Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Inc. - installed 2022-09-04)
[Loaded] com.adobe.ccxprocess.plist (Adobe Systems, Inc. - installed 2022-09-03)
User Launch Agents:
[Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Inc. - installed 2022-09-04)
[Other] com.google.keystone.agent.plist (Google LLC - installed 2022-09-04)
[Loaded] com.google.keystone.xpcservice.plist (Google LLC - installed 2022-09-04)
User Login Items:
[Running] gfxCardStatus (Cody Krieger - installed 2022-09-08)
Application
~/.switchGPU/bin/gfxCardStatus.app
Internet Plug-ins:
AdobeAAMDetect: 3.0.0.0 (Adobe Inc. - installed 2022-09-03)
Backup:
Time Machine Not Configured!
Performance:
System Load: 1.96 (1 min ago) 1.93 (5 min ago) 1.91 (15 min ago)
Nominal I/O usage: 0.42 MB/s
File system: 19.51 seconds
Write speed: 966 MB/s
Read speed: 772 MB/s
CPU Usage Snapshot:
Type Overall
System: 1 %
User: 2 %
Idle: 97 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
assistant_service 13.40 % (Apple)
WindowServer 13.10 % (Apple)
EtreCheckPro 7.88 % (Etresoft, Inc.)
kernel_task 4.40 % (Apple)
lsd (2) 2.76 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
com.apple.WebKit.WebContent (7) 1.43 GB (Apple)
MTLCompilerService (50) 1.34 GB (Apple)
EtreCheckPro 617 MB (Etresoft, Inc.)
Safari 173 MB (Apple)
kernel_task 154 MB (Apple)
Top Processes Snapshot by Network Use:
Process Input / Output (Source - Location)
mDNSResponder 72 KB / 66 KB (Apple)
com.apple.WebKit.Networking 118 KB / 10 KB (Apple)
apsd 32 KB / 7 KB (Apple)
trustd 26 KB / 2 KB (Apple)
assistantd 6 KB / 3 KB (Apple)
Top Processes Snapshot by Energy Use:
Process (count) Energy (0-100) (Source - Location)
WindowServer 3 (Apple)
PerfPowerServices 1 (Apple)
AXVisualSupportAgent 0 (Apple)
AirPlayXPCHelper 0 (Apple)
symptomsd 0 (Apple)
Virtual Memory Information:
Physical RAM: 16 GB
Free RAM: 777 MB
Used RAM: 7.52 GB
Cached files: 7.72 GB
Available RAM: 8.48 GB
Swap Used: 0 B
Software Installs (past 60 days):
Install Date Name (Version)
2022-09-03 X-Disk (1.0.3)
2022-09-04 XProtectPlistConfigData (2162)
2022-09-04 Incompatible Kernel Extension Configuration Data (15.1.1)
2022-09-04 macOS Installer Notification (2.0)
2022-09-04 Gatekeeper Configuration Data (181)
2022-09-04 XProtectPayloads (71)
2022-09-04 Gatekeeper Compatibility Data (1.0)
2022-09-04 MRTConfigData (1.93)
2022-09-04 MacPorts (0.2.7.2.0.0.0.0.0)
2022-09-04 Logo Store for Adobe Photoshop (1.1)
2022-09-04 ApowerMirror (1.4.5)
2022-09-04 IPTV Streamer (1.4.2)
2022-09-04 macOS Big Sur (11.6.8)
2022-09-04 Safari (15.6.1)
2022-09-04 Real Driver Legend of the City (0.6.3)
2022-09-05 Command Line Tools (13.2.0.0.1.1638488800)
2022-09-08 Command Line Tools for Xcode (13.2)
Diagnostics Information (past 7-30 days):
2022-09-08 22:17:52 AdobeIPCBroker.app - Crash
Executable: /Applications/Utilities/Adobe Application Manager/IPC/AdobeIPCBroker.app
2022-09-08 22:09:47 system_installd - High CPU Use
Executable: /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/system_installd
2022-09-08 21:50:58 gfxCardStatus.app - Crash (2 times)
Executable: ~/.switchGPU/bin/gfxCardStatus.app
2022-09-08 19:46:09 Kernel Panic
Details:
panic(cpu 4 caller 0xffffff8008bc3646): Kernel trap at 0xffffff7fa3695
5e2, type 14=page fault, registers:
2022-09-07 20:05:56 Kernel Panic (2 times)
Details:
panic(cpu 1 caller 0xffffff7f9f5884d9): GPU Panic: mux-regs 4 3 5f 1d
0 8 severity 3 WS-ready 1 switch-state 0 IG FBs 1 EG FBs 0:f power-sta
te 0 3D idle HDA idle system-state 1 power-level 20:20 power-retry 0 c
onnect-change 0 : NVRM[0/1:0:0]: Read Error 0x0010a050: CFG 0x0fe910de
0x00100406 0xc0000000, BAR0 0xc0000000 0xffffffa07b369000 0x0e7290a2,
D0, P2/4
2022-09-07 18:37:22 Kernel Panic
Details:
panic(cpu 0 caller 0xffffff7faaf884d9): GPU Panic: mux-regs 2 3 5f 1d
0 8 severity 3 WS-ready 1 switch-state 0 IG FBs 1 EG FBs 0:0 power-sta
te 4 3D idle HDA idle system-state 2 power-level 5:0 power-retry 0 con
nect-change 0 : NVRM[0/1:0:0]: Read Error 0x00000100: CFG 0x0fe910de 0
x00100406 0xc0000000, BAR0 0xc0000000 0xffffffa086d49000 0x0e7290a2, D
0, P0/4
2022-09-06 15:35:08 signpost_reporter - High CPU Use
Executable: /usr/libexec/signpost_reporter
2022-09-04 03:02:55 accountsd - Crash
Executable: /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Details:
*** Terminating app due to uncaught exception 'NSInternalInconsistency
Exception', reason: 'Unhandled error (NSCocoaErrorDomain, 256) occurre
d during faulting and was thrown: Error Domain=NSCocoaErrorDomain Code
=256 "The file “Accounts4.sqlite” couldn’t be opened." UserInfo={NSFil
ePath=/Users/***/Library/Accounts/Accounts4.sqlite, NSSQLiteErrorDomai
n=14}'
terminating with uncaught exception of type _NSCoreDataException
abort() called
2022-09-04 02:54:06 bird - Crash (2 times)
Executable: /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
Details:
dyld3 mode
Assertion failed: (db was corrupted
2022-09-04 02:54:04 keyboardservicesd - Crash
Executable: /usr/libexec/keyboardservicesd
Details:
dyld3 mode
Exception', reason: 'This NSPersistentStoreCoordinator has no persiste
nt stores (unknown). It cannot perform a save operation.'
terminating with uncaught exception of type NSException
abort() called
End of report
EtreCheck Report
Runtime: 3:12
Problem:
Major Issues:
Minor Issues:
Status: Vintage
Video Information:
Drives:
Mounted Volumes:
Filesystem: APFS
Used: 18.99 GB
Shared values
Free: 356.02 GB
Filesystem: APFS
Used: 729 KB
Shared values
Free: 375.00 GB
Filesystem: APFS
Read-only: Yes
Used: 15.32 GB
Shared values
Free: 161.80 GB
Filesystem: APFS
Used: 285 MB
Shared values
Free: 161.80 GB
Filesystem: APFS
Used: 1.07 GB
Shared values
Free: 161.80 GB
Filesystem: APFS
Encrypted
Used: 55.47 GB
Shared values
Free: 161.80 GB
disk3s6 - Update
Filesystem: APFS
Used: 7 MB
Shared values
Free: 161.80 GB
Filesystem: APFS
Encrypted
Used: 15.32 GB
Shared values
Free: 161.80 GB
Filesystem: APFS
Mount point: /
Read-only: Yes
Used: 15.32 GB
Shared values
Free: 161.80 GB
Disk Image
Owners enabled: No
Read-only: Yes
Used: 30 MB
Free: 14 MB
Network:
802.11 a/b/g/n/ac
System Software:
Security:
Unsigned Files:
Apps: 2
Old Applications:
3 x86-only apps
Launch Daemons:
Launch Agents:
User Launch Agents:
User Login Items:
Application
Internet Plug-ins:
Backup:
Performance:
CPU Usage Snapshot:
Type Overall
System: 1 %
User: 2 %
Idle: 97 %
symptomsd 0 (Apple)
Physical RAM: 16 GB
Free RAM: 777 MB
Used RAM: 7.52 GB
Swap Used: 0 B
Details:
Details:
D0, P2/4
Details:
0, P0/4
Details:
n=14}'
abort() called
Details:
dyld3 mode
Details:
dyld3 mode
abort() called
End of report
Your profile indicates that you're using a Macintosh. Is that correct?
I am using Macbook pro
Back up your Data and perform a clean install of the latest native supported OS. Before installing, make sure to reset PRAM thrice.
zaymen
