Sleep / Wake not proper
Hi , Thanks for the reply.
For the OC configurator issue...App latest version Re-Installation done.
Video attached. Hope this helps you.
This is App specific, contact the developer.
Reactions: kathir
Thanks for the quick reply. Will do that...
Waiting for an update should be the solution for now. Original Sleep/Wake issue fixed?
Hi, Original Sleep / Wake issue Fixed... Now I am using it for past two days...
1. I can put the machine to Sleep and Wake also works via USB Mouse.
2. Apple Magic Keyboard connects after wakeup and Audio Buttons working as intend.
Your Guidance is very useful and made the day for me. Thank you for it.
Finally Original Sleep / Wake issue resolved.
Now I have to look solution for Wake up the Machine by BT Apple Magic Keyboard.
The Current PR files in the attachment...
Hi... USB tab export files
sleepy_simon
