Getting stuck while booting to installer
Pranay
Hp Elitebook 840 G3 motherboard
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
Intel HD Graphics 520
  2. Clover (Legacy)
  3. OpenCore (UEFI)
  4. OpenCore (Legacy)
  2. iMac Pro
  3. Mac Pro
  4. Mac mini
  5. MacBook
  6. MacBook Air
  7. MacBook Pro
  3. Windows Phone
  4. Other
Hey team EliteMacx86,
I want to install MacOS Monterey in my HP elitebook 840 G3, so I made an EFI as per ur guide but when I booted I am getting stuck in the middle (Photo of error will be attached). So please say if there is any error with my EFI configuration (EFI will be attached).
Thank you
EFI
Thank you
EFI
Edit your config.plist as instructed below.
-Remove all the renames from ACPI>Patch section.
-Remove ResetLogoStatus Quirk from ACP>Quirks section
-Remove SyncRuntimePermissions and RebuildAppleMemoryMap Quirks from Booter>Quirks section
-Remove wegnoegpu arg and add -wegnoegpu arg in NVRAM>7C436110-AB2A-4BBB-A880-FE41995C9F82>Add>boot-args
-MacBookPro13,2 is a poor choice. Use MacBookPro13,1.
-Enable UnblockFsConnect Quirk in UEFI>Quirks section.
jkzql77089
