SOLVED Headphone/Microphone combo port acting weird (ALC295/3542)
Kernel
Dell G15 5510
Intel Core i7-10870H
Intel UHD Graphics 630
Hello! The headphone/microphone combo port is acting weird. If I increase the volume with a speaker connected, after a point static noises starts appearing frequently until after a limit the sound stops. If I connect a headphone, after a point the sound just becomes completely distorted. (Included screenshot for reference)
Using vanilla AppleHDA with AppleALC layout ID 13
The microphone also doesn't have any input.
No PR files attached.
The Audio implementation is not correct.
- You should not inject Layout ID on PciRoot(0x0)/Pci(0x1b,0x0) as it is required for Broadwell and prior.
- You're injecting Layout ID= 77 in HDEF, whereas, Layout ID=13 in boot arg. Both the Layout ID should be the same.
- Kexts sorting order is not correct. All mandatory kexts must load first.
- Unnecessary Drivers are added. Read below
Removed the entry.
Fixed HDEF layout ID, removed boot arg.
Tried to resort kexts, no drivers removed because I don't know which to remove.
The problem is still the same. Attached the new config.plist because only that was changed.
Read here
OK, so I will remove 3 drivers:
OpenPartitionDxe.efi
PS2MouseDxe.efi
UsbMouseDxe.efi
Removed them, issue still the same.
PS2MouseDxe.efi
UsbMouseDxe.efi
You need to remove the following
CrScreenshotDxe.efi
OpenNtfsDxe.efi
Ps2KeyboardDxe.efi
Try Layout ID=13 and then check. Make sure your kexts are up-to-date.
On a side note, make sure you're using a genuine AC Adapter.
Yeah, I am using the one that came with the laptop.
Already using layout-id 13.
Should I update to the latest OpenCore? (0.8.2->0.8.3)
Removed the drivers you said.
Also the speakers are detected as headphones and the output menu in system preferences says headphone port.
WYLDE983
