SOLVED Gigabyte z390n-wifi Ethernet, WiFi and Bluetooth not working
x8664
Gigabyte z390n Wifi
Intel i7 8700k
UHD 630
Currently have the latest Ventura installed and it's pretty stable, other than the Bluetooth / Ethernet - I mean I guess you could say they both technically work at first because I can pair with both my Magic Mouse and Keyboard and go to any website.. but given enough time my Ethernet craps the bed. It shows en0 being up and connected locally but I can't ping any external address... this leads my to think that since everything works at first that a kext needs to be updated for Ventura - either IntelMausi or SmallTree.. anyway this isn't a big deal for me since I have Monte working flawlessly.. I really just created a post to see if I'm doing anything wrong and maybe create dialogue around the z390n-wifi and Ventura
Ethernet
Intel I219V2 PCI Express Gigabit Ethernet:
  Bus:    PCI
  Vendor ID:    0x8086
  Device ID:    0x15b8
  Subsystem Vendor ID:    0x1458
  Subsystem ID:    0xe000
  Revision ID:    0x0000
  Driver:    as.acidanthera.mieze.IntelMausi
  BSD Device Name:    en0
  MAC Address:    e0:d5:5e:2b:82:16
  AVB Support:    No
  Maximum Link Speed:    1 Gb/s
Loaded 3rd party Kext
   51    8 0                  0x8a000    0x8a000    as.vit9696.Lilu (1.6.2) C593597E-8D3F-3164-B932-29A846C755E7 <9 7 6 3 2 1>
   52    0 0                  0xb000     0xb000     org.acidanthera.driver.CPUFriend (1.2.6) 67049832-3628-383F-B077-DC7F719BF045 <51 15 9 7 6 3 2 1>
   53    0 0                  0x1b5000   0x1b5000   as.vit9696.AppleALC (1.7.4) 49CC79FC-647D-3C4B-B8D4-18A8D9C34D25 <51 16 9 7 6 3 1>
   54    0 0                  0xd000     0xd000     org.acidanthera.NVMeFix (1.1.0) 5E4FD74C-6A65-3BB9-9C8F-82B9705204AE <51 9 7 6 3 2 1>
   55    0 0                  0xb5000    0xb5000    as.vit9696.WhateverGreen (1.6.1) CBA69AB3-B101-3B9A-841E-243971CBB7E6 <51 16 9 7 6 3 2 1>
   56    0 0                  0xa000     0xa000     as.acidanthera.BlueToolFixup (2.6.3) 783D6D6E-E28B-3C6F-AEA9-9590DC649332 <51 9 7 6 3 2 1>
   57    0 0                  0x2a5000   0x2a5000   as.acidanthera.BrcmFirmwareStore (2.6.3) 6AABD988-749E-39EE-819D-FB6CD9396872 <7 6 3>
   58    2 0                  0x29000    0x29000    as.vit9696.VirtualSMC (1.3.0) 180B2207-900E-3469-B233-C81E9C1F3E84 <51 15 9 7 6 3 1>
   59    0 0                  0xf000     0xf000     as.vit9696.SMCProcessor (1.3.0) 3897D8E5-4208-3D08-B7D8-E49F91DC4D43 <58 51 15 9 7 6 3 2 1>
   87    0 0                  0x2b000    0x2b000    as.acidanthera.mieze.IntelMausi (1.0.8) 3E0D584A-2F0A-31B6-BE15-9D361B7C0E82 <49 16 7 6 3 1>
   88    0 0                  0x3f000    0x3f000    ru.joedm.SMCSuperIO (1.3.0) BB8AB597-B3BF-3FB6-A106-D17B81C46948 <58 51 15 9 7 6 3 2 1>
   89    0 0                  0x30000    0x30000    com.smalltree.driver.SmallTreeIntel82576 (1.3.0) FC2E800A-F5FF-3F86-AF25-58E04BEDFBC3 <49 16 7 6 3 1>
   95    0 0                  0x6d5000   0x6d5000   com.zxystd.IntelBluetoothFirmware (2.1.0) EB72D6E1-12D7-3035-8E82-2EC10ED3F7A9 <24 7 6 3>
My EFI is kinda bloated since this has been a four day project of me just rolling around plugging in various things to test...
Ethernet
  Bus:    PCI
  Vendor ID:    0x8086
  Device ID:    0x15b8
  Revision ID:    0x0000
  AVB Support:    No
Current EFI
This is normal with macOS Ventura. This has been already covered. See the Ethernet section for more information.
Read below
I've updated all the various kexts, patched the DMAR tables and enabled VT-d still only connects for around 5 min then times out or crashes. It's not looping either, at least not that I can tell from watching the pref pane - I'll just wait for more updates or until I can afford a better card.
This is regarding WiFi/Bluetooth or Ethernet?
Bluetooth works, both Wifi and Ethernet will drop connection after a period of time.
Provide your BIOS Settings, Hackintool PCIe Report, IOReg, Kextcache output and your current EFI.
BIOS
CSM Support - Disabled
Initial Display Output - IGFX
Above 4G Decoding - Enabled
PTT - Disabled
SW Guard Extensions (sgx) - Disabled
Trusted Computing - Disabled
Legacy USB support - Enabled
XHCI Hand-off - Enabled
USB Mass Storage Driver Support - Enabled
Port 60/40 Emulation - Disabled
VT-d  -  Enabled
Internal Graphics - Auto
DVMT Pre-Allocated - 64M
DVMT  Total Gfx Mem - Max
Platform Power Managment - Enabled
You'll have to give me a command for the kextcache output, I looked around and couldn't get it to output anything useful for me...
Execute the following commands in Terminal
sudo kextcache -i/
sudo kextcache -i/
I get
Unknown option '--check-rebuild'
Provide System Report and Hackintool>System Export Data
J.An
