Lenovo Ideapad S540-15IWL - Intel Core i5-8265U - 8GB RAM - Intel UHD Graphics 620
This is a complete installation guide to install macOS Big Sur 11.2.3 on Lenovo Ideapad S540-15IWL. The purpose of this guide is to provide a step-by-step guide to install Big Sur using OpenCore UEFI.
Specifications
| Component | Model Number |
| Tablet | Lenovo Ideapad S540-15IWL |
| Processor | Intel Core i5-8265U |
| RAM | 8GB 1866MHz |
| Graphics | Intel UHD Graphics 620 |
| SSD | Samsung 512GB NVMe SSD |
| Audio | Realtek ALC257 |
| Display | 15.6” FHD (1920x1080) IPS, antiglare, 300 nits, 72% NTSC |
| Wireless/Bluetooth | Replaced with Broadcom BCM94352Z, NGFF, M.2, A+E Key Type |
| WebCam | SunplusIT Integrated Camera |
| Fingerprint | GoodixFingerPrint |
| Ports | 1 x DC Power Input | 1 x HDMI | 2 x USB 3.0 | 1 x USB Type-C Gen2 | 1 x 3.5mm audio combo jack | 1 x SD Card slot |
Summary
| Features | Status |
| Graphics | YES |
| Built-in Audio | YES |
| Brightness | YES |
| Brightness HotKeys | YES |
| Fingerprint | NOT SUPPORTED |
| WebCam | YES |
| Battery meter | YES |
| Card Reader | YES |
| Ethernet | YES |
| WiFi/BT | YES |
| AirDrop | YES |
| Handoff | YES |
| Apple Watch Unlock | YES |
| Power Management | YES |
| App Store | YES |
| iMessage | YES |
| FaceTime | YES |
| iCloud | YES |
| USB 2.0, and USB 3.0 Ports and Type-C | YES |
Not working
- Fingerprint is unsupported and it doesn't works.
- There is a known issue with Samsung PM981 series NVMe. The SSD was replaced with Samsung 970 EVO Plus.
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
6. Enter your password
| Directories | Description |
| Docs | Contains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore. |
| IA32 | Contains OpenCore EFI, 32-bit OpenCore Boot Loader. |
| Utilities | Contains several utilities. |
| X64 | Contains OpenCore EFI, 64-bit OpenCore Boot Loader. |
Adding Required SSDTs
| SSDT Name | Notes |
| SSDT-EC-USBX |
| SSDT-AWAC |
| SSDT-PLUG |
| SSDT-PNLFCFL |
Adding Required Drivers
| Driver Name | Required | Notes |
| OpenRuntime.efi | YES |
| OpenHfsPlus.efi | YES |
| OpenCanopy.efi | Optional |
| AudioDxe.efi | Optional |
3. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
- All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
| Kext Name | Required | Notes |
| Lilu | YES |
| VirtualSMC | YES |
| WhateverGreen | YES |
| AppleALC | YES |
| SMCBatteryManager.kext | YES |
| AirportBrcmFixup.kext | YES |
| BrcmBluetoothInjector.kext | YES |
| BrcmFirmwareData.kext | YES |
| BrcmPatchRAM3.kext | YES |
| USBInjectAll | YES |
| Sinetek-rtsx.kext | YES |
| VoodooI2C.kext | YES |
| VoodooI2CHID.kext | YES |
| VoodooPS2Controller.kext | YES |
1. Download the above kexts.
Notes:
- Use the kext from RELEASE folder and RELEASE.zip file.
- Do not place unnecessary kexts here. It might prevent booting the installer.
- Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
- The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
| SSDT Name | Notes |
| SSDT-EC-USBX |
| SSDT-AWAC |
| SSDT-PLUG |
| SSDT-PNLFCFL |
ACPI>Patch
| Table Signature* | Find | Replace | Comment | Enabled | Notes |
| DSDT | 47465830 | 49475055 | Rename GFX0 to IGPU (Graphics) | NO |
| DSDT | 48454349 | 494D4549 | Rename HECI to IMEI (PAVP)* | YES |
| DSDT | 4D45495F | 494D4549 | Rename MEI to IMEI (PAVP)* | YES |
| DSDT | 48444153 | 48444546 | Rename HDAS to HDEF (Audio) | YES |
Booter>Quirks
Notes:
- *Requires both renames for full function.
- GFX0 to IGPU rename must be enabled after ACPI patching.
Booter>Quirks
| Quirks | Value | Notes |
| AvoidRunTimeDefrag | YES |
| EnableSafeModeSlide | YES |
| EnableWriteUnprotector | YES |
| ProvideCustomSlide | YES |
| SetupVirtualMap | YES |
| SyncRuntimePermissions | YES |
Note:
- The values which have been not discussed above, that will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. The following changes are needed.
| Devices | Key | Value | Type | Notes |
| PciRoot(0x0)/Pci(0x2,0x0) | AAPL,ig-platform-id | 0900A53E | DATA |
| device-id | A53E0000 | DATA |
| framebuffer-con1-busid | 01000000 | DATA | ||
| framebuffer-con1-enable | 01000000 | DATA |
| framebuffer-con1-type | 00080000 | DATA |
| framebuffer-con2-enable | 01000000 | DATA | ||
| framebuffer-con2-index | FFFFFFFF | DATA | ||
| framebuffer-con1-enable | 1 | NUMBER |
| framebuffer-fbmem | 00009000 | DATA |
| framebuffer-patch1-enable | 1 | NUMBER |
| framebuffer-stolenmem | 00003001 | DATA |
| hda-gfx | onboard-1 | STRING |
| PciRoot(0)/Pci(0x1f,3) | hda-gfx | onboard-1 | STRING |
| layout-id | 30 | NUMBER |
| no-controller-patch | 1 | NUMBER |
Kernel>Add
| Arch | BundlePath* | ExecutablePath | PlistPath | Enabled | Notes |
| Any | Lilu.kext** | Contents/MacOS/Lilu | Contents/Info.plist | YES |
| Any | VirtualSMC.kext** | Contents/MacOS/VirtualSMC | Contents/Info.plist | YES |
| Any | WhateverGreen.kext** | Contents/MacOS/WhateverGreen | Contents/Info.plist | YES |
| Any | AppleALC.kext** | Contents/MacOS/AppleALC | Contents/Info.plist | YES |
| Any | AppleBacklightFixup.kext** | Contents/MacOS/AppleBacklightFixup | Contents/Info.plist | NO |
| Any | SMCBatteryManager.kext | Contents/MacOS/SMCBatteryManager | Contents/Info.plist | NO | |
| Any | AirportBrcmFixup.kext | Contents/MacOS/AirportBrcmFixup | Contents/Info.plist | YES | |
| Any | AirportBrcmFixup.kext/Contents/PlugIns/AirPortBrcmNIC_Injector.kext | Contents/Info.plist | YES | ||
| Any | BrcmBluetoothInjector.kext | Contents/Info.plist | YES | ||
| Any | BrcmFirmwareData.kext | Contents/MacOS/BrcmFirmwareData | Contents/Info.plist | YES | |
| Any | BrcmPatchRAM3.kext | Contents/MacOS/BrcmPatchRAM3 | Contents/Info.plist | YES | |
| Any | USBInjectAll.kext** | Contents/MacOS/USBInjectAll | Contents/Info.plist | YES |
| Any | Sinetek-rtsx.kext** | Contents/MacOS/Sinetek-rtsx | Contents/Info.plist | NO |
| Any | VoodooI2C.kext/Contents/PlugIns/VoodooGPIO.kext | Contents/MacOS/VoodooGPIO | Contents/Info.plist | NO | |
| Any | VoodooI2C.kext/Contents/PlugIns/VoodooI2CServices.kext | Contents/MacOS/VoodooI2CServices | Contents/Info.plist | NO | |
| Any | VoodooI2C.kext | Contents/MacOS/VoodooI2C | Contents/Info.plist | NO | |
| Any | VoodooI2C.kext/Contents/PlugIns/VoodooInput.kext | Contents/MacOS/VoodooInput | Contents/Info.plist | NO | |
| Any | VoodooI2CHID.kext | Contents/MacOS/VoodooI2CHID | Contents/Info.plist | NO | |
| Any | VoodooPS2Controller.kext | Contents/MacOS/VoodooPS2Controller | Contents/Info.plist | YES | |
| Any | VoodooPS2Controller.kext/Contents/PlugIns/VoodooInput.kext | Contents/MacOS/VoodooInput | Contents/Info.plist | YES | Delete this entry after postinstallation. |
| Any | VoodooPS2Controller.kext/Contents/PlugIns/VoodooPS2Keyboard.kext | Contents/MacOS/VoodooPS2Keyboard | Contents/Info.plist | YES | |
| Any | VoodooPS2Controller.kext/Contents/PlugIns/VoodooPS2Mouse.kext | Contents/MacOS/VoodooPS2Mouse | Contents/Info.plist | YES | |
| Any | VoodooPS2Controller.kext/Contents/PlugIns/VoodooPS2Trackpad.kext | Contents/MacOS/VoodooPS2Trackpad | Contents/Info.plist | YES |
Notes:
- All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
- The mandatory kexts must be loaded in sorted order as shown in the above table.
- *Indicates BundlePath i.e. Name of the Kext
- **Indicates mandatory kexts.
- All the added kexts must exists in the EFI/OC/Kexts directory.
- The options which have been not discussed above, that will remain untouched.
Kernel>Scheme
| Options | Value | Notes |
| FuzzyMatch | YES |
| KernelArch | Auto |
| KernelCache | Auto |
Kernel>Quirks
| AppleCpuPmCfgLock | YES |
| AppleXcpmCfgLock | YES |
| CustomBIOSGuid | YES |
| DisableIoMapper | YES |
| PanicKNoextDump | YES |
| PowerTimeoutKernelPanic | YES |
| XhciPortLimit | YES |
| DisableLinkeditJettison | YES |
Note:
NVRAM>Add
| UUID | Key | Value | Type | Notes |
| 7C436110-AB2A-4BBB-A880-FE41995C9F82 | boot-args |
| STRING |
| csr-active-config |
| DATA |
| prev-lang:kbd | en-US:0 | STRING |
PlatformInfo
Suggested SMBIOS
| SMBIOS | CPU |
| MacBook Pro14,1 | Intel Skylake for i3, i5 and i7 |
DataHub
| Option | Value | Notes |
| Add this section in config.plist | YES | Adds DataHub field |
Generic
| Add this section in config.plist | YES | Adds Generic field |
| from SMBIOS | YES | |
| ProcessorType | 0 |
| SystemMemoryStatus | Auto |
| SpoofVendor | YES | Sets SMBIOS vendor fields to Acidanthera |
PlatformNVRAM
| Option | Value | Note |
| Add this section in config.plist | YES | Adds PlatformNVRAM field |
SMBIOS
| Add this section in config.plist | YES | Add SMBIOS field. |
UEFI
This section is for adding UEFI drivers and related settings. This section will remain completely untouched
Note:
The values which have been not discussed above, that will remain as default values.
Installing OpenCore EFI
2. Copy the EFI from your working directory to EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts and config.plist and the USB Flash drive is ready to boot off your computer.
UEFI Settings
| Settings | Value |
| SATA Emulation | AHCI |
| Network Boot | Disabled |
| Virtualization Technology | Enabled |
| Legacy Support | Enabled |
| Secure Boot | Disabled |
| Fast Boot | Disabled |
Once the UEFI is setup, Save & Exit Setup
Installation
Turn on your system.
6. Repeat step no. 5.
| Name | Macintosh HD |
| Format | APFS |
| Scheme | GUID Partition Map |
12. Close Disk Utility.
This will take couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here it ends the first phase of the installation.
Post Installation
Now, configuring the Post Installation. There is not much to do for the postinstallation except configuring WiFi/BT and the boot from system drive. Everything rest is fully functional.
DSDT and SSDT Patching
For the DSDT and SSDT patching, i prefer full patched set of DSDT and SSDT. For more information on DSDT and SSDT patching, checkout the guide linked below
https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
Using the guides, patch all of your DSDT and SSDT.
DSDT
- Layout id = 11 (0x11)
- Lenovo Ideapad-100
- Rename GFX0 to IGPU
- Fix _WAK Arg0 v2
- HPET Fix
- SMBUS Fix
- IRQ Fix
- RTC Fix
- OS Check Fix (Windows 10)
- Fix Mutex with non-zero SyncLevel
- USB3_PRW 0x6D Skylake (instant wake)
- GPIO Controller Enable [SKL+]
into method label _REG parent_hid PNP0C09 insert
begin
//added to turn nvidia/radeon off\n
If (LAnd(LEqual(Arg0,3),LEqual(Arg1,1)))\n
{\n
External(\_SB.PCI0.RP05.PXSX._OFF, MethodObj)\n
\_SB.PCI0.RP05.PXSX._OFF()\n
}\n
end;
SSDT
- Cleanup/Fix Errors (SSDT)
- Remove _PSS placeholders
Find the following lines and delete them.
External (_SB_.PR00._PPC, IntObj)
External (_SB_.PR00._PSS, BuffObj)
External (_SB_.PR01._PPC, IntObj)
Patch for Disabling GPU in SSDT-9-CB-01
into method label _INI parent_label \_SB.PCI0.RP05.PXSX insert
begin
_OFF()\n
end;
Place all the patches DSDT and SSDTs to EFI/OC/ACPI
1. Open your config.plist
2. Add all the DSDT and SSDTs.
Note:
- The DSDT and all the OEM SSDTs must be added in a sorted order.
- The SSDT (SSDT-PNLFCFL.aml) should be added at last.
The kexts for the Brightness and Trackpad already exists in the required directory and the ACPI has been patched accordingly. You just need to enable the disabled patch and kexts in your config.plist.
Boot from System Drive
3. Open your EFI Partition of your Hard Drive.
6. Copy the EFI folder from your macOS Bootable USB to your EFI Partition of your Hard Drive.
By using this method, you’ll be easily able to install OpenCore Boot loader on your System Drive.
Restart your Laptop
After completing the post installation, restart your laptop.
App Store, iMessage, FaceTime, and iCloud
1. Mount your EFI partition
2. Open your config.plist
3. Navigate to Platform Info Tab
4. Generate a new SMBIOS for "MacBook Pro14,1"
5. Save your config.plist
6. Restart your Tablet
7. Login into App Store, iMessage, FaceTime and iCloud.
Conclusion
You should have all the functions as stated above.
Credits:
